Question about Hitachi GCR-8240N CD-ROM Drive
Hitachi-lg data storage gcr-8481b jumper setting
Slave setting needed
3 Suggested Answers
  • 3278 Answers
SOURCE: Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Hello.
For most IDE drives, if you REMOVE the jumper, the drive becomes a slave. But, you'll also need to change "drive 1" in your BIOS to recognize the second drive.
If you look on the drive, there should be a scheme as to the mode (Master, Slave,etc.).
Hope this helps.
Posted on Nov 07, 2009
  • 1705 Answers
SOURCE: is there a jumper setting
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Posted on Mar 26, 2011
How to set jumpers on a hitachi hard drive
Use the above diagram to set the HDD in the required mode.
For more details on Master and Slave modes please use the below link
http://www.ehow.com/how_6031_change-master-slave-designation.html
Aug 18, 2011 | Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Installing Hitachi Deskstar 40 GB drive as slave. Where do the connectors go. It says model IC35L060AVV207-0. Installing drive in Dell 4600
Look at the "connectors" end of the disk-drive.
There will be a set of thin pins for the "data" cable,
and thicker pins for the "power" connector,
and a smaller grid of small pins.
It's these pins that will be labelled/engraved on the casing:
MA(ster), SL(ave), C(able)S(elect).
Move the jumper to the "slave" setting.
Connect to the power connector.
Connect to a "data" cable.
When you add power to your computer, it should recognize the drive.
Dec 26, 2010 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
Installing a second cd drive..LG GCR 85258
When you install a cd drive it is very simple. Make sure the plug is unplugged out of wall outlet. Then push power button for any remaining power left in pc. Then open up pc connect wires to drive and screw drive in place.5 minute job. Good luck.
Aug 13, 2009 | LG gcr8520b Internal 52x CD-ROM Drive
CD Rom installation
the cdprom power cable port might be faulty plz check it ...
Jul 07, 2009 | Computers & Internet
How do you set a LG GSA-H10A DVD Drive as a Slave?
on the drive there will be printed or stamped:
MA, SL, CS (maybe in a different order.) Often there is a printed label, and often the re are tiny letters stamped either above or below the jumper pins.
You need to place a jumper in the vertical position over 1 set of pins corresponding to the map above.
ie if you want the drive to be a Master, jumper the vertical set marked (or indicated) as MA.
If you want it to be Slave, jumper the SL set.
If you want the drive to be set depending on where on the IDE ribbon cable is conected, connect the pins marked as CS.
BIOS will then allocate the drive as either a master or slave.
Using Internet Explorer but not Firefox, get the manual here:
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=GSA-H10A&initialTab=warranty&targetPage=support-product-profile#
Note the manual is a dejaVu document which will ask to load a viewer plug-in into Internet Explorer.
Actually, inside that document, there is a drawing indicating that reading from left to right (ie from next to audio connector), the pins are: CS,SL, MA. So for example upper and lower pins at the extreme left are Cable Select, so you would jumper those 2 pins.
Cheers,
Steve
May 16, 2009 | LG GSA-H10A Burner
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Hitachi GCR-8240N CD-ROM Drive Logo
88 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
