Question about LG WM-2277HW Front Load Washer
DE error code on LG washing machine
I've replaced the PCB main assembly AND the door lock switch, but the dE error would not go away and the washing machine would not start - any idea?
  • 4 Answers
Beyond that could just be the door latch itself.
Posted on Jan 06, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
If you have changed the main control board and the door switch, the only other component that can cause this is the User control and display board.
Posted on Mar 28, 2014
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
SOURCE: de error on my lg washing machine
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Posted on Oct 17, 2010
Gives a error code DE Why is this
DE is door error on Samsung washer
means door is not locking
door lock or main PCB Door lock is the cheapest of the 2
Jul 02, 2015 | Washing Machines
De error but the machine have not door switch
if its front loader door swich is there,,but toploader no door swich but with main pcb having sensor,,locking with door lid with megnet,,,
Feb 08, 2014 | LG Washing Machines
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
LG WM2277HW dE error code coming up at end of cycle. Door is locked, cannot open or reset to get clothes out.
Hi
Thanks for using FixYa. DE is a door open error, you’ll have to check the door if it’s properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
My washer is not locking the door it sounds two clicks and is showing the leter in scream DE what is that means
HI. This is a Door Open error code.
Here are 4 reasons for this issue:
* The Door may not be all the way closed
* Loose electrical connections at door switch and pwb assembly.
Ok. You have stated that the unit is attempting to lock the door, but it is not locking. There are two click, then the error code illuminates the DE code. This is common when the control cannot initiate a door lock sequence. The cause will be a failed door lock mechanism, and it will require you to replace this mechanism asap, if possible. The actuator has failed. Replacing the door switch mechanism, will correct this issue.
Oct 19, 2009 | LG WM-2277HW Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
Jul 11, 2009 | LG Washing Machines
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
LG WM-2277HW Front Load Washer Logo
202 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
