Question about Cuisinart CMW-100 Microwave Oven
Microwave doesn't work
The microwave powers up but the magnetron doesn't activate
    New Friend:
How do I get a manual for the euro pro t021
Posted on Nov 23, 2013
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Oct 01, 2012 | Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
My microwave makes a loud humming noise when it is turned on.
May as well use the microwave as is until it terminates naturally. All microwave ovens buzz, that nothing unusual, but although you can replace a Magnetron, the cost is unusually high. By the time you take the oven down, open the case and fuss around, perhaps not making things any better; the fact is; a new replacement with a warranty is just over $100. Why bother?
Feb 04, 2018 | Microwave Ovens
My microwave makes a loud humming noise when it is turned on. What do I need to replace?
Good possibility your start capacitor is leaking. When it goes completely it will blow fuse or circuit breaker causing a dead condition. You can get and replace this yourself but be careful to discharge the capacitor with a set of test leads across the terminals. This part can hold dangerous voltage! Of course, unplug the unit first. The magnetron is expensive if you can even get one. For the cost of most new units, this may be too much unless it’s a over the stove model.
Feb 04, 2018 | Kenmore 69682 Microwave Oven
MY MICROWAVE DOEST HEAT, IT LOOKS LIKE WORK NORMALY BUT DOESN HEAT
pull your magnetron connector out and clean the both pins with alcohols or a metal cleaner and then fix it again and use. magnetron will work surely.
Oct 03, 2009 | Samsung MW8574W Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
76 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
deton8 von Splosion
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
