Question about Craftsman Garden
Battery was smoking. replaced it and nothing happens. lights do not come on and engine makes no sound.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Make and model of tractor with type of engine would help here... did you check for a blown fuse ???
Posted on Nov 25, 2013
2012 Harley Road King won't start. Tried jumping the bike with a portable jumper. The bike started twice but as soon as the jumper was disconnected the bike died. On the third attempt some smoke came from...
Go to your battery find out where that smoke is coming from. It sounds like summer your wires melted together. That was cause everything the short out, make sure your battery is charged, take it out of the bike and charge it and make sure you got about 12.67 V coming out of it. When you tested smoke coming from anywhere as bad. You could have some wires melted together file your wire harness, make sure that's not so
Feb 23, 2015 | Road Motorcycles
Possible electrical problem?
Diagnosing something from a description is far from an exact science, but this is what it sounds like to me may have happened. If your battery was not tie down it could have gotten against something hot or moving (like a pulley), or what ever was rattling may have created a spark somehow and caused the battery to exploded, either way the battery fluid spashing onto hot metal could explain the cloud of white smoke, as you did not mention seeing any flames.
Nov 06, 2013 | 1999 Toyota Camry
My van would have issues with starting for months. I would have to try starting it up about 5-8 times before it would start up. Battery is new and has been tested twice within the last few months and it...
HI youtube12 - IT sounds like your starter deed not disengage from the flywheel and
by you driving it caused the starter over heat and short out .
You need to have the electrical sys checked out before replacing starter. OK
good luck ziggyone
Sep 16, 2011 | Dodge Grand Caravan Cars & Trucks
Engine do not start (no cranking), only the sound of clicking (relay??). All indicators are normal (lights up), battery good (tested by turning on headlights, blowing horn). Happens after turning off a hot...
Hi:) That sound like the solenoid is the problem it is located on the starter and if the solenoid is not working right it will do all the things you are explaining.And yes heat has alot to do with it and being ware out.If it is the original it is time to replace the starter anyways it's 16 years old.
Mar 08, 2011 | 1995 Toyota Corolla
Engine does nothing when key is turned no power getting to starter , starter and battery were replaced, smoke comming from engine compartment when key is turned
sounds like a positive wire or ground wire has come loose and is burning on something causing no power to the starter and also causing the smoke
Jul 12, 2010 | 1992 Pontiac Grand Am
Engine dies while driving
kinda sounds like fuel pump or egr valve you cuold disconnect the egr valve and retest if problem goes away replace the valve.white smoke tells me egr hope this helps TUNDERBOLTZ
Jan 13, 2010 | Toyota Camry Cars & Trucks
My 1998 Rav4 gives off a few seconds of black smoke at engine start. No other problems have presented. Anyone tell me what is going on? Thanks in advance!
You may have an excessive rich mixture due to a sensor malfunction that is causing excessive fuel enrichment., The part that gets me is that you don't have a check engine light on. a 98 Rav4 is an OBD2 vehicle and should have thrown a code and turned on the check engine light ,if you have a bad sensor Black smoke is usually a sign of too much fuel, blue smoke is a sign of oil being burned and white smoke or steam is usually a coolant leak into the combustion portion of the engine, Verify the color of smoke and go from there. Some enrichment at start up is normal because cold engines need enrichment to start and run properly till warmed up.. Goodluck
Aug 25, 2009 | 1996 Toyota RAV4
What causes engine smoking on EJ-DE engines?
sound like leaking valve seals. make sure oil return holes not stop up.
Mar 28, 2009 | 1992 Daihatsu Rocky
Try to start car and nothing happens. replaced
Do the dash lights come on ? They should come on when the key is turned to the on position. If nothing happens check the engine relay. It is not too expensive to replace if you really want to eliminate that as the problem. Check all wires going to the starter and make sure it is wired correctly.
Feb 28, 2009 | 2001 Pontiac Aztek
Electrical Problems
Do not leave the car in the garage without the battery disconnected until you locate the source of the smoke, the best tool to find the smoke's source is your nose, smell the area around the source of the smoke, if you smell a really nauseating smell you found it, then look for signs of burnt wires or burnt components, also look for any oil that may have caused the smoke, but I doubt that was the source, this sounds electrical. I know of no problems for your car that would cause this, so most likely it is not a common problem.
Oct 19, 2008 | 2003 Mazda Tribute
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
