Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Replaced battery and will not make a sound - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    Scholar:
  • 46 Answers
Troubleshoot as follows: 1. Using a set of jumper cables connect the Black side of the jumper cable between to the (-) of battery and a the block of the engine. Connect one (red) end of the jumper cable to the (+) of battery...And just touch the other end of the red cable to where to mower battery cable touches the starter. *Only tap it and starter should turn over. This bypasses all switches and wiring. If it does not turn the starter, the starter is likely bad. If it does turn over, check the starter solenoid, seat safety switch, blade engagement safety switch, clutch brake switch, or wiring in between those components. A wiring diagram would be most helpful. It came with the mower, or can be found online...likely at a sears/craftsman web site, but sometimes also at parts retailer website too. Similar bypass method can be used for troubleshooting. DO NOT OPERATE WITH BYPASSED SAFETY SWITCHES, ETC. Bypassing is for troubleshooting only.
Posted on Nov 25, 2013
Car died replaced battery died again after 2 days. Possible cause?
yes .it also sounds like your alternator has failed.get it checked
Jan 25, 2018 | 2006 Chrysler Town & Country
Battery releases charge after being parked for about 15 mins
sounds like you may not have enough liquid in the battery ,but if the battery is full of water,it sounds like you may have a dead cell or cell's,check the battery with a load tester,after charging the battery,take the neg.battery cable off the battery,then in a few min.test the battery with a load tester,
Dec 30, 2012 | 1995 Nissan Quest
Wont start but makes weird stuttering sound
Sounds like the battery is low on charge or is in need of replacement in most cases.
I would not change the starter until trying a new battery that is fully charged.
Dec 19, 2010 | 2005 Mercedes-Benz C-Class
THe ding dong was sounding "sick" like the batteries were low so I replaced them and now there is no sound at all - and yes the batteries are installed correctly. THought perhaps I needed to replace the...
Might have bad battery connections,do to rust or moistures.Take some cotton balls,dips it in with some rubbing alchahols,clean all the battery connections.Wait like half an hour,reintall the battery,see what happens.
Oct 12, 2010 | Desa International White Wireless Plug In...
No sound through phone speaker
If it is under warranty, have it replaced. If not buy the insurance and have it replaced. Depending on what type of phone, it could either be the ringer itself, or a bad software problem. Try removing the battery and with battery removed hold the power button for 20 seconds, and replace battery and see if it works. If not, get a new phone.
Feb 03, 2010 | Cell Phones
My battery died and after replacing the battery nothing happens
Did you mean there is NO sound from the starter? The question says there is now sound from the starter. If it is a quick clicking noise, the new battery needs to be charged. Try getting a jump start for it or returning the battery, it should have come charged already. Not a good sign, these things sometimes bought new come with bad cells.
Jan 12, 2010 | 2001 Saturn SL
My battery will not recharge and the volume does not work
Battery:
Portable batteries are consumable and have a expected lifespan of roughly 300 to 500 recharge/discharge cycles before replacement is required. If you are using the original battery, then most likely you need a new one. If battery is a new replacement and you have the same issue, flash the BIOS to most current, see if any change. If not change, and a new battery doesn't charge, then replace the motherboard.
Volume:
You were not clear if this is a NO SOUND or just VOLUME IS LOW issue. For NO SOUND
  1. Open Volume Control, Ensure that sound is not muted.
  2. Control Panel, Sound and Volume controls. Ensure that the sound card is selected as the primary playback device.
  3. BIOS, ensure the Audio is Enabled.
  4. Download and reinstall the audio driver.
If you are just talking about the volume control displaying on screen, reinstall the quickset utility
Nov 15, 2009 | Dell Inspiron 9300 Notebook
Car won't start clicking sound
sounds like a battery to me
check the voltage in the battery
try putting a battery charger on it
Apr 20, 2009 | 1998 Dodge Stratus
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
99 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
