Question about Epson Office Equipment & Supplies
Manually move ink carrier epson xp-410 - Epson Office Equipment & Supplies
3 Suggested Answers
SOURCE: Epson C82, Cartridge carrier won't move
Hi, I'm having other belt problems but it sounds like the belt has separted from the carriage. The belt is held in place by looping through a place on the back of the carriage. It is just pressed into the plastic structure so if the plastic has broken or the belt worked out, your problem would occur.
It is a bit tricky in getting the carriage released. I found it necessary to completely remove the inner workings from the casing. A few screws and plastic clips to release but not too bad.
The trick comes in when you have to release the slide bar that runs through the carriage. It is held in place by small clips on either end. Both must be removed. They appear to be fiber so don't be too rough on them. There is a white plastic mounting on both ends which allows the print head to adjust for envelopes or paper. The one on the left (while looking at the printer from the front) must be removed. Be sure and mark the position of the bracket before removing. Take the screw out and rotate the piece so that the lugs will pass through the housing. Once removed, the bar can be slid through the opening and out of the carriage. You can then ease the belt off the motor gear (on the left) and inspect the "u" shaped connection on the back of the carriage. There is an area of the belt which is noticeably thicker than the rest of the belt and this is what should be inserted in the "u". If the plastic is broken you will probably have to replace the carriage. Good luck.
I have included a link below from another site which gives you a pdf of the service manual for the C82
http://www.eserviceinfo.com/downloadsm/18686/Epson_Stylus%20Color%20C82.html
Posted on May 01, 2008
albertgamayo
  • 10 Answers
SOURCE: epson tx121 cartridge not recognized-head carrier banks towards left side for long time
you need to short the fuse [F] board no. is F1
Posted on Nov 25, 2012
Installed new ink cartridges. noyw when I try to print I get blank pages
FAQs - Epson XP-410, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
Epson[ Answer ]; How do I print with black ink when a color cartridge is expended? [ Answer ]; I see the message Printer is Offline when I try to print with a wireless ...
Epson XP-400, Top FAQs - Technical Support - Epson ...
Epson[ Answer ]; What should I do if my product is printing blank pages? [ Answer ]; I don'thave the CD that came with my product. How do I install the software for my ...
Epson XP-810, Top FAQs - Technical Support - Epson ...
Epson
Feb 05, 2016 | Epson Expression XP 410 Wireless Printer
Epson xp-410 printer
XP 410 User Guide
replacing ink cartridge on the left will show you how
Aug 05, 2014 | Office Equipment & Supplies
How can I fix a shifted part in my Epson XP-410?
push it downward and if it is broken you have to speak with authorized service
May 07, 2014 | Epson Expression Home XP-410 Small-in-One...
Have an Epson NX200. Need to change ink cartridge but ink carrier will not position so I can open it.
usually you can move it manually with your hands .Turn off first your printer .once it turns off pull the carrier, pull the white tape gently to the center and just replace it ink cartridges there. Make sure its properly plug in .Once your done return the move the cartridge carrier manually from left to right 5x once your done you may now close the cover .(close it first ) And checked if its going to the center once you open the cover .
Hope it help thanks
May 26, 2011 | Epson Stylus NX200 Printer
Change ink
Usually, with an inkjet printer to change the cartridges, open the cover and then press the power button - or the other button, if there is one. Don't be afraid to press buttons ..
The cartridge carrier will then move from its 'parked' position to a more central, accessible position. Unclip the cartridge retaining clip and simply lift the cartridge out. Virtually all inkjet printers work on this principle.
Don't try and manually force the cartridge carrier along from its parked position otherwise you will cause damage.
May 17, 2009 | Epson Stylus C20UX InkJet Printer
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
