Question about Uniden DCT648-3 Cordless Phone
Uniden DECT RO35BT - Extension blue link light flashing
This unit includes base station and 2 DECT repeater/chargers - the base station/answering machine, and one repeater works fine. The 2nd repeater/charger has its "LINK" blue light constantly flashing. I have unplugged batteries from all handsets, disconnected power, all to no avail. The 2 repeater/chargers are sitting next to each other - one has "LINK" light steady, and clearly registered to basestation, whereas the other always blinks.
  • Tim Durrant Nov 23, 2013
    Just confirming the model # is DECT RO35B. I clearly typed in the correct model number into my Fixya problem, but Fixya decided to use a different model... because mine wasn't in the database. go figure :-)
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
SOURCE: i have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Posted on Jul 08, 2009
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
SOURCE: Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Posted on Feb 02, 2010
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
Aug 11, 2014 | Uniden DECT 6.0 Cordless Phone
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Answering machine on light keeps flashing but does not turn on unit
The headset(s) and the base station need to be re-sync.
Check the bottom contacts (base and headset) and let them sync (3+ minutes) OVER-NIGHT if the headset are low on battery.
This will sync the security code.
Jan 16, 2014 | Panasonic KX-TG1031S DECT 6.0 Expandable...
DECT 1480-4 Uniden Corless phone- how do you get rid of red LED lite ?
Do you mean the status light on the handset or the one on the base? The status light on the base will be on if the answering system is on. The handset status light will be on but steady when the handset is on the charger. (It's a battery charging indicator in that case; take the handset off the charger to stop the charging system. It provides a trickle charge to offset the battery discharging over time) The light blinks to indicate new messages are available on the answering system. Press the Play button on the base or the Messages/Mute button on the handset to play new messages.
Uniden offers the manuals for many of their phones on their support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The direct link to the manual for the DECT-1480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf .
I hope this helps.
Dec 02, 2011 | Lands Phones
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
Enjoy!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
We just bought a new uniden phone system and the Answering Machine keeps answering the phone after 2 rings. I set the base machine setting to answer after 6 rings but it didn't change.
If you have changed the setting on the base station and that did not work, power your base station off completely and try again if that does not work you have an out of box defect and need to exchange it.
May 06, 2011 | Uniden DECT 6.0 Cordless Phone ID
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden DCT648-3 Cordless Phone Logo
51 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
