Question about PNY 4GB Secure Digital High Capacity Memory Card
Pny sdhc card protected
My card won't work it says that the memory card is protect even when I unlocked it on the card, someone please help!!!!!!
  • PNY Master
  • 27,725 Answers
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab. Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
Posted on Nov 28, 2013
  • 28 Answers
SOURCE: PNY 4 G USB DISK IS WRITE PROTECTED
Not sure what exactly is happening when you try to use the disk. Is it a used disk? Did you just purchase it? Do you get an error when trying to use it?
From the limited information, I would suggest going to the website and seeing if there is a solution from PNY: http://www2.pny.com/support/support_landing_cat.aspx?SectionID=1143 (their support page).
If it still doesn't work, post more details & I'll see if I can help.
Have a good day!
Posted on Jul 23, 2008
tecnomage201
  • 221 Answers
SOURCE: Cannot remove write-protect from PNY 4gb usb2 memory stick
If you are attempting to remove the software that was preloaded on the drive, simply reformat it.
remember to copy any data that you have written to the thumb drive before attempting the reformat.
Posted on Apr 26, 2009
  • 25 Answers
SOURCE: just baught pny-4gb sdhc card, asks to format-no luck
You may have the card locked so that the format isn't taking. Verify that there isn't something that is physically preventing the format. If the slide is in the locked position move it to the opposite side.
Posted on Oct 24, 2009
laikexpert
  • 281 Answers
SOURCE: i cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
  • 50 Answers
SOURCE: my pny 2gb micro sd memory card is
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk Management. Select the micro SD drive and click Delete. Right-click on empty drive and select New Partition.
Posted on Jul 05, 2010
I bought this card at walmart , put it in my camera it says card error card not unlocked how do i fix this
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 14, 2013 | PNY 8GB Micro SD Memory Card
Canon S2 IS says memory card error"card locked" how do I unlock it?
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2013 | Canon PowerShot S2 IS Digital Camera
Olympus T-100, write protect shows on the screen & won't operate ??
Sep 09, 2012 | Cameras
Card protect won't allow me to take photos
SD and SDHC memory cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 05, 2012 | Video Cameras
Memory Card is protected; Reset switch on Memory Card
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 11, 2012 | Cameras
How to unlocked pny optima sd memory card 4gb
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
My camera is tellling me Memory card is write protected, won't let me take pictures siince I downloaded pictures onto my computer?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 13, 2011 | Nikon COOLPIX S700 Digital Camera
Just bought x500 digetal camera and can't figure out why it says write protect on screen will not allow to take pictures the memory card is a PNY optima 4GB with the memory card out it allows 3...
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 13, 2011 | GE Cameras
My PNY 4GB micro sd HC memory card for my cell phone says its write protected and won't let me transfer anything on to it. How do I remove the write protection. I already tried to switch it into an...
The problem might be that the card is password protected, i recommend you switch it to the unlocked position and then use a computer to format the memory card and do a full format not the quick format.
hope this helped.
Mar 06, 2011 | PNY 4GB microSD High Capacity Mobile Media...
PNY 4GB Secure Digital High Capacity Memory Card Logo
144 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
