Question about RCA 27V530T 27" TV
My tv has no sound
It has no sound but there is a picture i have to use subtitles but there annoying. the tv is connected to a satellite using a wire than plugs into the back of the tv
    Top Expert:
  • RCA Master
  • 12,962 Answers
If you are feeding an rf signal to your tv, the problem lies within the tv's audio circuits after demodulation of the signal. Try feeding a composite video and audio signal into set and see what happens. If set works then problem is definitely in the front end of the tv. If still nada you have a repair on your hands.
Posted on Nov 23, 2013
Sound loss on my television When watching on Thursday last at 12noon. The mute button on my remote indicates that the sound is on but there is no sound every else works picture and subtitles
Try to turn the tv volume up its possible that even though your tv says its not muted the volume is all the way down, and if thats not the case it is possible that the volume was to high and the speakers blew out, or there is a bad connection to the speakers, like inside the tv the connection to the speakers are burned up, like the wires or the motherboard their attached to
Oct 01, 2016 | Televison & Video
Hi I have a Toshiba CT-90326 Television. How do I disable the Audio Description on it? Thank you
Hello Clare,
CT-90326 is actually the model number of the remote control rather than the TV. It doesn't really matter as the correct button on the remote is more relevant than the actual TV.
The Audio description is a feature of the closed-caption/subtitle settings on your TV. You should be able to switch off the audio description by pressing the "SUBTITLE" button on the top row of the remote control. Each time you press this button it will cycle between ON and OFF.
If this doesn't work, it's probably because you are using a cable/satellite/digital receiver. If this is the case, look for a button on your cable/satellite/digital receiver remote control marked "CC" "CCD", "SUBTITLE".
Please try the above and then reply to me from within this page. Please state the model number of the TV and any cable/satellite/digital receiver you are using if/when replying.
Thanks,
BElectric
Jan 28, 2011 | Toshiba Televison & Video
I was using the satellite remote to find another show when the TV picture went black, then a minute or two later, the audio stopped. The satellite signal is still there (It is being received by another...
Hello.
First you have to figure out location of problem. That means is it inside of your new TV or outside of it?
Best way is to connect DVD player with new set of wires to different input and make sure it is working fine picture and sound wise. If OK - connect it to the same input that you are using with satellite box right now. If it works just fine - problem is outside of TV and originated in box or connection cable.
If DVD player does not work on any input - you have to call your TV manufacturer and schedule an appointment for repair tech. It is should be free of charge because you have 1-year warranty.
Or you can simply return/exchange your TV at the store you purchased it from (depend on store policy).
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Laptop connection to TV - Sound Problems HELP!
#Select the best HDTV package for PC and laptops to suit your needs. #Plug HDTV USB Stick into any USB port on your computer.
#Connect your Antenna cable, cable TV cable, or satellite cable to your HDTV USB stick.
#Install your TV tuner software.
Jan 14, 2010 | Sony VAIO (PCWA-A200)
No picture or sound magnavox mwd200g dvd player
on the side of the tv mostly there is a button for dvd mode you will have to press that button to reach in dvd mode.if no such button then its the cables fault or the wires are not connected properly just check out this link for connections
For tv/dvd /vcr connections
http://www.funai-corp.com/support/setup.aspx?prod=dvd2tv2vcr
For tv/dvd /vcr question answers.
http://www.dvddemystified.com/dvdfaq.html#1.27
Mar 02, 2009 | Philips Magnavox MWD200G DVD Player
New straight out of the box, TV no picture and no sound
If this is working in another room I suggest you check the connection from wherever that particular wire comes from ex. splitter or directle from the antenna I do not know where you tapped in that line. I hope this helps you out.
Nov 28, 2008 | GPX KCL8806DT 7 in. Portable Television
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
RCA 27V530T 27" TV Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
