Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Lost my remote can i buy a new one for my ceiling fan
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
If you have the receiver in the canopy, then yes. You probably have to replace the receiver & transmitter .
Posted on Nov 25, 2013
  • 34 Answers
SOURCE: the remote control turns the ceiling fan on and
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 09, 2009
SOURCE: Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
Posted on Jan 24, 2010
  • 736 Answers
SOURCE: hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Posted on Apr 16, 2010
  • 351 Answers
SOURCE: I have a Hampton Bay ceil fan model # AC-552
Hampton Bay is an exclusive brand of Home Depot. They would be the ones to help you with that. BUT .. from my experience I would say that the cost and trouble of getting and replacing the motor in that fan would be easilly rivalled by the cost and ease of buying and installing a new fan all together.
Please Vote !!
Posted on Jun 02, 2010
  • 2841 Answers
Home Depot sells parts and can get you almost any replacement part for your fan. Know you fan has a lifetime warranty at Home Depot. You can go to the store or call them at (1-800-654-0688). Here is another source for parts.
http://www.eceilingfans.com/accessories_-_ceiling_fans.html
Posted on Nov 20, 2010
Remote Control Dock
Should be, but the separate cradle may be hard to find.
Nov 26, 2017 | Hampton Bay 24002 Ceiling Fan
I have a Hampton Bay ceil fan model # AC-552 "NN" and the serial # 000371. We had lost power in our neiborhood a while back and was use the generator and when the power came back on our fan didn't work....
Please Vote !!
Jun 02, 2010 | Hampton Bay 52 In. White Redington...
Fan speed control UC7058RY produced by RHINE, need to order replacement? For St. Regis 60" Hampton Bay Ceiling Fan.
hi Januszkop,
I have the same ceiling fan. However, I lost the remote control. Do you know where I can buy it? Thanks.
Oct 24, 2009 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Feb 05, 2009 | Hunter (25417) Ceiling Fan
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Aug 16, 2008 | Dryers
May 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
43 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
