I had a Lennox G71 installed a couple months ago. It worked fine but in the last week it has shut down twice with error code E273 - Any ideas?
SOURCE: Lennox Gas Furnace that turns on and shuts off in minutes
After troubleshooting like mad, I found that the flame sensor (rod that sits within the flame) was fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once I pulled out the rod and cleaned it with a wire brush, I have no problem whatsoever--fixed.
Posted on Nov 20, 2008
  • 85 Answers
SOURCE: Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Posted on Dec 09, 2008
johnsonr1
  • 91 Answers
SOURCE: lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
http://tech.lennoxintl.com/C03e7o14l/mk6x6w5J5/503526e.pdf
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Posted on Nov 04, 2009
  • 215 Answers
SOURCE: The unit will turn on and run fine for a few
The ignitor will light, the blower will start up and run for a few minutes and then the system will shut down, and the blower will continue to run and cool down. The ignitor is not working properly, the ignitor has carbon build-up and need to be removed, cleaned all the black carbon from the ignitor with a little piece of sand paper and replaced, turn the heat back on and this should correct the problem.
Posted on Dec 14, 2009
SOURCE: I have Lennox pulse 21 control module light goes out
If this is a high eff model, check to make sure the intake vent is not plugged.
Posted on Jan 18, 2010
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Lennox pulse 21 startup issues .does not engage fan and complete heat cycle every time .
Have seen a rash of faulty blower time delays in lennox equipment. Lennox has a recall on one currently, not sure if your system is effected but it can be bypassed if in fact the problem.
Aug 23, 2017 | Heating & Cooling
My 1995 BUICK PARK AVENUE cranks up, and drives fine. when I go to slow down it just shuts off on me. It started a couple months ago, but only happened once or twice. A couple days ago it did it 7...
Have someone take the mass air flow sensor off and clean it with a non-chrlonated brake cleaner.Make sure its dry before reinstalled and do not touch wire inside sensor with your fingers the oil from your fingers can damage it.
Apr 21, 2011 | 1995 Buick Park Avenue
Jan 17, 2010 | Heating & Cooling
Humming sound from the washer
Sounds like the pump is locked up for some reason could be something stuck in it,I have pulled a lot of nickels out those for some reason, they are the perfect size to get down into the pump and get stuck.
Sep 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Dec 09, 2008 | Heating & Cooling
Screen freeze.
1. you need to install the pc software 2. you need to connect the system to your pc via the usb cable 3. switch the system on - it should be seen as a mass storage. 4. Start PVR Console and run a disk checkup - this should run without error - run this twice. 5. Try the unit now - does it work?
Apr 16, 2007 | Goodmans GPDR40 Digital Media Player
Heating & Cooling Logo
215 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
