Question about RTO Bernzomatic Brushed Nickel Patio Heater
The pilot lights and stays lit. When I try to ignite the burner, the pilot goes out as soon as I turn the knob.
    Top Expert:
  • RTO Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  • Disconnect the gas line from the heater by unscrewing the coupler attached to the gas inlet valve near the bottom of the burner or base of the unit.
  • 2 Remove the top cover from the heater, following the manufacturer's instructions. Typically the cover is held on by a screw and nut at the top or multiple screws around the perimeter. You may need a screwdriver to remove the screws.
  • 3 Look at the burner assembly, which is where the flames typically emerge. Open a bottle of rubbing alcohol and saturate the end of a cotton swab with it. Rub the cotton swab over the holes around the perimeter of the burner assembly to clean away grease, dirt and debris that may be clogging it.
  • 4 Look at the back of the burner assembly to find the venturi tubes, which are small silver tubes with holes in the end. Insert a pipe cleaner gently into the end of each tube and push it in until you feel resistance. Twist the pipe cleaner in a circle and pull it straight out to remove any spider webs that are blocking the inside.
  • 5 Reassemble the cover on the patio heater by reversing the steps taken to remove it. Reconnect the gas coupler to the inlet valve and turn on the heater to test the pilot ligh
Posted on Nov 24, 2013
5 Suggested Answers
  • 6 Answers
SOURCE: I have been trying to ignite heater but it will
I had the same problem and fixed it with a small piece of Aluminum foil, an adjustable wrench, and a #2 screwdriver... If you're "handy", this is an easy 30 minute fix. I included a picture that may help you visualize the "fix" before attempting. In short, I'm not certain what happened or why/how it broke, but if you remove the valve/manifold you can blow air into the gas inlet (with your mouth) and adjust the knob and you will see that only when it's all the way pushed down you can blow air through the valve, otherwise n air/gas can not get through. Thats why the pilot will light, and when you let the knob out the flame goes out. If that is your problem, this fix will work. After I put the foil (explained below) to extend the brass pushrod that allows gas to enter the manifold, it worked as expected allowing air/gas to enter only when on "light" and through the LO to High sweep.
Step 1) Shut off gas and remove tank.
Step 2) Remove the black gas On/Off knob (pulls off)
Step 3) Remove the three on thumb screws inside the tank storage area to allow the entire top/heater mesh to slide down (like intended to store it, or how it came shipped in the box). Sliding this down will expose the bracket the manifold/valve mounts to.
Step 4) Remove the spring clip and washers from the stem on the valve. Remember the order, and dont lose any parts as this works your igniter. (I usually take a picture with my phone on these types of things, so I can recall how they went.)
Step 5) Carefully remove all the gas lines from the valve and the grounding wire at the rear of the manifold.
Step 6) Remove the two small Phillips screws that hold the valve to the bracket.
Step 7) Remove the valve from the unit.
Step 8) Remove the two small #2 Phillips screws that hold the aluminum and the brass parts together on the valve.
Step 9) Give a slight tug and the two pieces will come apart easily. A small aluminum part may fall out; this is okay as it only goes in one way.
Step 10) Take a small piece of aluminum foil 1 1/2 inches by 7 inches or so, and wadd it tight into a ball. I used pliers to get it tight and small (bigger than BB, but smaller than the end of a pencil eraser) You will see that it needs to go inside the channel where the brass stem will slide in and out of the "slotted" tube on the stem.
Step 11) Put it back together and try the "blow test" again to see if the aluminum ball was the right size to make it work ...again. I had to do this a few times to get the right size "extension". Also, be sure to blow into the "main" gas inlet and adjust the gas control knob through the push in and "light" the pilot mode all through the Hi/Lo sweep.
Reverse your steps and give it a try. Mine lights every time and works perfect. ...actually better than new, as it was always a task to light.
Hope this was helpful, as this was my first post...
Posted on Dec 15, 2009
  • 6 Answers
SOURCE: i have a bernzomatic patio heater. i can get the
See my reply on this other post. http://www.fixya.com/support/t3536737-trying_ignite_heater_but_will
  • 122 Answers
SOURCE: Pilot light will not stay lit!!
It sounds like it could be a faulty thermocouple or your not letting it stay on long enough to heat the thermocouple.
Hope this helps
Mike
Posted on Jan 30, 2010
  • 569 Answers
SOURCE: Pilot Lights when control knob
Check that the pilot light is directed at the thermocouple, a copper 'tube' that heats up when the pilot light is lit. You should be able to see a copper coloured small tube that the pilot light is directed at - if the pilot flame is not heating that tube then the main burner will not light.
If the thermocouple is being heated correctly, then it could be a fault with the thermocouple itself (can be replaced) or the gas valve.
If the pilot flame is not heating the end of the thermocouple you should be able to adjust its position so that the pilot flame is directed at it more accurately.
Posted on Jan 17, 2011
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
My Delonghi Propane Heater will not stay lit.
this sounds strangely like a safety switch problem , ill bet the device that confirms the pilot lite lit before going to main burner has a problem
Jan 19, 2013 | DeLonghi SafeHeat Heater
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
The burner will only stay lit for a few minutes
Hello. Begin by using a small brush to clean everything in that area. Then light the pilot and light the burner. If it still acts up, change the thermocouple. Regards, joe
Nov 22, 2009 | Computers & Internet
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
RTO Bernzomatic Brushed Nickel Patio Heater Logo
144 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
