Question about Crosley CR8006A-OR Retro Radios
I cannot set. time and alarm, just radio. How can I proceed?
Set time on the sylvania Bluetooth radio scr1996-pl
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Mar 08, 2015 | Radio Communications
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Apr 23, 2014 | Audio Players & Recorders
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Sep 19, 2010 | Memorex MI4019BLK Alarm Clock Clock Radio...
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
instead.
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
Crosley CR8006A-OR Retro Radios Logo
24 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
