Question about Refrigerators
What's the weight capacity of a Jenn-air CS 6018 which is a motor
2 Suggested Answers
SOURCE: Looking for a part for my Jenn-Air electric motor
I broke the same part when trying to manually turn the shaft on a stuck motor. That part is made out of pot/white metal. Mine broke at the base where it slides onto the half round shaft on the motor. I was able to fix it by drilling a small hole in the half round shaft on the motor and the broken piece. Then I used a small finish nail as a pin to hold the two parts together. Next time I take it apart, I will use some JB Weld epoxy on it. I don't think you'll find that piece by itself. I might just tinker on my metal lathe and make one up, but looking on ebay is probably your best bet for the whole motor.
Posted on Jul 20, 2009
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I need a motor for the turn-table.
HI.coil of the armature and the rotor(the one rotating) is the main problem why motor will not work.Eitherthose coils were burnt and short circuited and thus it requirres repair.Creating such coil will not be done manually because of its very tiny pieces..coils diameter is too small. To do it manually.It was actually coiled assembled using a machine.Now if your motor is defective the only way is tonrecoil it by manufacturer or purchse a new motor that has the same power output capacity ,voltage and current requirement.You can actually purchase that in a hardware or sapare parts store.Hope this idea helps.Thank you for choosing fixya.
Jul 16, 2011 | Jenn-Air JMC7000 Microwave Oven
What is the maximum towing capacity for a 1987 chevy caprice brougham..? ( the 305 engine) Thanks!
With a 20 year old vehicle, the original towing capacity does not apply.
I'd set a limit of whatever the weight of your vehicle is as a safe number (if car weighs 3,200 lbs, tow weight is 3,200lbs Max.) Trailer weight is also determined by the capacity of the hitch.
Trailer loading should be at 60% of weight on hitch.
Don't forget...you need a fully functional cooling system, adequate (most times additional) transmission cooling, and good suspension (air shocks, variable load rear springs and fresh differential lube). If this is done, you may be able to add 20-30% more trailer weight.
One item often overlooked is that it really does not matter if you can pull a load...you need to be able to stop it. Make sure your brakes are in really good condition!!!
Mar 19, 2010 | 1987 Chevrolet Caprice
Jul 15, 2009 | Jenn-Air Grilling
Jenn air jsd2789hes making humming noise every 2
check the motor relay, if the relay is good. check the motor compresor w/d **** tester, if your riding high ampers...the problem is in the motor compreso.
Apr 26, 2009 | Refrigerators
Jenn-Air Microwave turntable not working, microwave works
It's probably a cracked coupler or a weak, slipping motor.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 03, 2007 | Jenn-Air JMC8130DD Microwave Oven
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
