Question about Craftsman 7.8 Generac Generator Engine Muffler Exhaust 4200 Watt Part No. 83071
Need manual for craftsman generator 580.32674
Craftsmen 4000 generator circuit board
Generac made these for sears craftsman, so that would be a replacement board if needed ? I have replaced them before servicing generators, hope this answers your question ?
Feb 23, 2015 | Electrical Supplies
Maunual for generator #580.32670
How do you replace the cam in the motor of a craftsman model 580327360
Nov 06, 2013 | Craftsman Briggs & Stratton Generator,...
Wiring diagram for generator
What generator make and model do you need a wiring diagram for?
Sep 17, 2013 | Electrical Supplies
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
My craftsman 5700 generator has gas inthe oil...why?
your float is stuck and wont shut of the needle and seat so it floods make sure you shut fuel of when not running and check your needle and seat and see if it shuts of the fuel from the tank
Oct 29, 2012 | Craftsman 5600 watt Generator
I have an older Craftsman 750 watt generator model 580.328310. Serial # on this unit is 029434. Unit runs great. I am looking for foam air filter, rubber foot for bottom and new gas gauge.
Take a look at the http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580328310/0247/0702250?pathTaken=
look for the parts that you need and you can order them direct from Sears.
Jan 09, 2011 | Craftsman Garden
The unit starts and runs but does not put out any electric . it is a craftsman 5600.is there a fuse or reley
Most generators do not have any fuse in them, but they have "diodes" and "capasitors". When any of these go bad there will be on output from the generator even if it is running.You will need to open up generator to locate these components.
May 09, 2010 | Electrical Supplies
Craftsman 7.8 Generac Generator Engine Muffler Exhaust 4200 Watt Part No. 83071 Logo
292 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
