Question about Whirlpool SB160PEE Gas Single Oven
I just refilled my propane gas tanks and gas is coming through the top burners but there is no flame. I hear the clicking sound it makes when the pilot light ignites but no flame at all. What do I do ?
  • 3 Answers
Air won,t burn ther is air between the tank & the burner try using putting a flme at the burner then tun on the burner it should start after the air passes through the hose
Posted on Dec 14, 2013
5 Suggested Answers
  • 4 Answers
SOURCE: one top burner makes clicking sound
it's telling that your ***. Sorry :)
Posted on Mar 20, 2009
SOURCE: gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Posted on Jul 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: ignitor lights up bright, but no ignition,no flame
Hello, welcome to fixya ! Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven won't lite. Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, 1) need to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2) ignite the fuel once said gas valve is open. A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not lite at all ) but yet not reach the needed value to open the gas valve/safety valve consistently nor adequately, hence the need to replace the ignitor. Try this and I'm certain you'll be up & running and as they say " cookin' with gas" ! I'd suggest you should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 and it will work in your Whirlpool too. Try places like repairclinic.com, searspartsdirect.com, APwagner.com etc. Thank's for visiting "fixya" for your stove inquiries. Please take a moment while here to rate the solution provided or let me know if you require further assistance and good luck. macmarkus :)
Posted on May 23, 2010
Testimonial: "Very good! I knew I could coun't on you for info on my oven. It's great to have professional help online. Thank-You ! Jeff (Doc)leisinger"
  • 257 Answers
SOURCE: Gas Stove top seems to
Sounds like it's not getting gas. Check to make sure all gas line valves are turned on and the tank has gas in it.
Posted on May 14, 2011
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Purchased a used gas oven yesterday. The top burners are working fine, but the oven is sooting up. We live in the country and use propane, but did not receive any additional orfice or instructions. In the...
We need a model number to be specific.
Check the gas regulator and make sure the pressure cap has been set for propane.Most of them are turned over to put more pressure inside the valve.
If so. Check the air shutter on the bake gas tube and adjust for the best color flame.
Also tighten the bake burner orifice with a 1/2 inch wrench.
Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
A friend has a oven that has been coming on with a bang. I've cycled it on and off cold and hot no problems when I was there. Pulled the botten pan out (it is quite worped from heat and dosn't fit that...
a lot of iffy things could be happening here..
verify proper amperage draw through the ignitor.. i believe thats a 3.2-3.5 amp system but check the label thats on the gas valve, it will have the ratings listed on there for sure. make sure amperage draw is in the middle of the range as some gas valves are less tolerant of low amperage draw than others.
it almost sounds like your amperage load may be on the low side, just enough to open the valve regularly but not open fully..
its on its way out if so..
the popping could be the gas coming into the oven slowly enough to NOT blow directly across the ignitor properly, (igniting it instantly if it were) and allowing it to pool in the enclosure some because of the low amperage draw through the ignitor, eventually firing with a bang..
yes the regulator vent could be plugged, but another thing is if you are on bottled gas/lp/propane for your source of fuel the regulator at the tank could be faulty also, causing the pulsing flame..
hope this helps,
best of luck,
ttfn
Nov 02, 2009 | Jenn-Air Ovens
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Oven slow to heat and top burners weak flame
sounds like you have a gas pressure /flow problem. id start with hte gas company have them come out and check you tank pressure(if using LP), or the pressure from reguator leading to home
Mar 13, 2008 | Ovens
Whirlpool SB160PEE Gas Single Oven Logo
69 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
