Question about Delta Saws
Motor runs, blade doesn't go - Delta Saws
    Sergeant:
  • 468 Answers
Have you called the Tech reps from the manufacturer of your band saw? I suggest you to call a tech rep. Are you sure you install the blade correctly?
Posted on Nov 25, 2013
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Motor turns but blade doesn't
Is the shaft turning...? if so then refit the blade . If the shaft is not
turning then you need to get the motor out and check to see if the
shaft and motor are connecting or not, can you do this job yourself
if not, take it to someone who can..T.C.
Mar 22, 2013 | Saws
Blade doesn't move (reciprocate)
The drive shaft for the blade is stripped or broken. take it back where you bought it.
Oct 31, 2012 | Dewalt DW303 Heavy Duty 65 Amp...
Band saw very noisy
This could be several things. To find the noise, unplug it, open the covers and turn the wheels by hand to see if you cand find where the noise is coming from - this might help you find the source of noise if it the blade is hitting something it's not supposed to. If that doesn't find it, you might try removing the blade entirely and running the motor to see if the motor is the source of the noise. If that doesn't find it, you might try putting a different blade on. Good luck.
Oct 21, 2012 | Saws
White z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
Apr 11, 2012 | Oregon Scientific Electric PTO Clutch for...
Delta 1313314 motor runs but blade doesn't turn
With this perticular motor I would suspect that the issue is a broken drive belt. The belt is located on the back side of the motor, behind the plastic end cap. The belt is a 10" long cogged belt and looks like a timing belt.
Jan 20, 2012 | Delta Saws
My motor was just rebuilt and put back on by the pool company. It is hot, so hot you cannot leave your hand on it. Is this normal? should I be concerned.
Yes its perfectly normal on a hot day with the motor being air cooled. As long as the motor isnt overheating (loss of power) and has issues running your fine. Keep in mind that the motor runs by exploding gasoline and the energy that doesn't get transferred to the mower to drive it and turn the blade is expelled in heat. Same as your car engine (will get hot to the touch).
May 13, 2011 | Garden
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
Saws Logo
43 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
