Question about Dryers
Electrolux How To Repair
I pressed the start button but the dryer doesnt turn and as such isnt working. All of the lights are on, it makes the noises and you can change the setting. Is this a common problem.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
If you are hearing the motor running and it is heating you might have a broken belt
Posted on Nov 25, 2013
Testimonial: "The belt isnt broken:)"
SOURCE: DRYER IS NOT WORKING
Is your belt broken?
Posted on Nov 30, 2007
  • 1314 Answers
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
Posted on Feb 15, 2008
SOURCE: dryer not turning on
Mine stops if it overheats and you have to let it cool down and then press a reset button on the back. It could also be fuse or it may have tripped the breaker.
Posted on Mar 27, 2008
IFIXALL
  • 868 Answers
Mode land serial number?
Posted on Jun 02, 2008
SOURCE: Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Posted on Oct 16, 2008
My Fisher and Paykel Dryer wont spin... The lights will turn on and press start and it makes a noise like it wants to spin, but it doesnt... the last few times I had to mannually move the inside around,...
This usually means that your belt is broken once you replace the belt in the dryer it should turn the electric motor in the dryer and you should be fine
Feb 07, 2018 | Dryers
When i push the start button the unit .The dryer makes a noise but doesnt start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 25, 2011 | GE DBLR333GE Gas Dryer
We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
May 03, 2011 | Electrolux Dryers
All the power is on but when I press the start button it makes a clicking sound and won't work it doesnt spin or dry
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 26, 2010 | GE 7.0 Cu. Ft. Super Capacity Electric...
I have an Electrolux IQ Touch dryer. Just now it stopped working. When I hit the start button, it makes a buzzing sound and then goes on Pause. I called Electrolux and they had no idea what was...
Dryer Repair ? The dryer will not start
heatman101
Aug 25, 2010 | Electrolux Dryers
Maytage neptune dryer wont start
heatman101
Feb 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Noisy electrolux dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tyu634
Mar 02, 2009 | Electrolux EIGD55H Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
