Question about Garden
Will a chaincase off a 2005 rx1 fit on a 2004 rx1
    Top Expert:
  • 12,223 Answers
You must ask to the manufacturer to due the design insight of the engine . Contact them via ONLINE chat and get the support.
God bless you
Posted on Nov 24, 2013
How do you do the drive chain adjustment on my 2005 Polaris 900 rmk 159 track
To adjust chain tension in the chaincase, loosen the jam nut on the chaincase with a 9/16" wrench a few turns. Then turn the adjustment ***** in with your fingers until it can't be turned by hand anymore. Once that point is reached back the ***** out 1/4 turn and tighten the jam nut. Best of luck, Daniel
Mar 12, 2016 | ATVs
Drive belt installation 2000 electreaglid classic
Remove the rear wheel and then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly and then remove the primary chaincase housing. Support the bike under the rear fork and engine and then remove the pivot shaft and the spacer THEN slip the belt off the transmission sprocket and then install a new drive belt over the transmission sprocket and proceed to reinstall the pivot shaft and spacer after which you can remove the support holding the engine and rear fork and install the primary chaincase housing, the primary chain assembly and the primary chaincase cover and fill the primary chaincase with lubricant up to the bottom of the clutch diaphragm spring. Install the rear wheel and adjust the belt to the proper deflection dimension and confirm that the rear wheel is properly aligned side to side.
Jul 08, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
How do you change the drive belt on a 2006 hd sporster
Remove the rear wheel and then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly and then remove the primary chaincase housing. Support the bike under the rear fork and engine and then remove the pivot shaft and the spacer THEN slip the belt off the transmission sprocket and then install a new drive belt over the transmission sprocket and proceed to reinstall the pivot shaft and spacer after which you can remove the support holding the engine and rear fork and install the primary chaincase housing, the primary chain assembly and the primary chaincase cover and fill the primary chaincase with lubricant up to the bottom of the clutch diaphragm spring. Install the rear wheel and adjust the belt to the proper deflection dimension and confirm tat the rear wheel is properly aligned side to side.
May 21, 2014 | 2004 Harley Davidson XL 883 Sportster
How to replace drive belt on 1993 harley davidson?
Is it a softail????
To remove a Softail drive belt FIRST remove the rear wheel then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly, then remove the primary chaincase housing, place a support under the rear fork and engine, remove the pivot shaft and spacer, slip the drive belt off from the transmission sprocket.
To replace a Softail drive belt FIRST not that all belts, used or new, must never be formed into a loop smaller than 5.0 in. (130 mm), and must never be bent backwards because this can severely weaken the belt and cause premature failure if it, then install the belt over the transmission sprocket, install the pivot shaft and spacer, remove the support holding the engine and rear fork, install the primary chaincase housing, the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster and the primary chaincase cover, fill primary the primary chaincase with oil, install the rear wheel, align the rear wheel and properly adjust the belt tension to the specified deflection.
Apr 28, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
How much oil goes in the primary chaincase on a 1999 fxd
Hi Anonymous, how about 26 oz. of Harley Davidson Primary Chaincase Lubricant. Good luck
Feb 04, 2014 | 2005 Harley Davidson FXD - FXDI Dyna Super...
2004 primary oil capacity 2004 dyna
Hi Anonymous, 26 oz. HD Primary Chaincase Lubricant. Good luck
Dec 21, 2013 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
How do you put oil in primary on 2004 wide glide and how much does it hold
Hi Anonymous, 32 oz. Primary Chaincase Lubricant, for more information about your question please visit the website below. Good luck and have nice day.
Motorcycle Repair Changing the Primary Chaincase Oil on 2008 Harley...
Jul 29, 2013 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
How much oil does the primary hold on a 2005 heritage softail flstc
Hi Anonymous, 26 oz. HD Primary Chaincase Lubricant. Have nice day.
Aug 03, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
My 2005 harley night train leaking oil from the transmission how do i repair it.
This needs a new gasket normally, unless there has been some impact damage which has cracked the casing(?) Check where the leak is coming from. If it is further in towards the middle of the bike it could be a crack or a seal between the gearbox and primary chaincase. If it is under the chaincase, you need to remove the footrest/boards and remove the chaincase screws, hitting the outer cover with a rubber mallet to break the seal, and taking off the chaincase cover, clean off the old gasket and applying a new one with some silicone sealer. Make sure you drain the oil from the chaincase or you will have a huge mess!
Sep 16, 2009 | 2005 Harley Davidson FXSTB - FXSTBI Night...
1957 pre unit inner chaincase felt washer position
Inner chaincase has sprungfork plate rivited on, between which you should have a large plain washer and felt washer that are in situ before inner case is located over GB mainshft. if you have the projecting brass sleeve (bearing) this will fit inside felt/washer on assembly. Its not critical and you wont lose a lot of oil even if you dont use the above.
Aug 20, 2009 | Triumph Thunderbird Motorcycles
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
