Question about Koolatron 12 Volt Battery Saver 70110
WHAT IS THE PROPER SEQUENCE TO CONNECT THE BATTERY SAVER & REFRIGERATER TO THE 12V OUTLET? IS THE CAR STARTED BEFORE OR AFTER THE BATTERY SAVER/REFRIGERATOR ARE PLUGGED IN?
    Problem Solver:
  • 16 Answers
Oyu might burn up the battery saver,its not designed to run devices
Posted on Nov 25, 2013
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Amp burning
the power supplyis burnt or tosted it can be fixed but make sure u find a good shop to take it to or u can call me at 256-698-9903
Jul 08, 2010 | Swiss Audio SDX1000 Car Audio Amplifier
Alarm and battery failure ; Powerware 9102
open the screws and disconnect the battery look the voltage written on it and AH (ampere/hour) e.g.12v & 7ah and purchase same value battery and connect look carefully the +ve &-ve polarity of battery and connect in proper way
Feb 24, 2010 | Powerware 9120 UPS System
Does not turn off and drains the battery
do u have the amp hooked to a switched terminal of the igntion switch?
Jul 22, 2009 | Insignia 600W Bridgeable Amplifier with...
Car Alternator, 2007 Citi Golf
the citigolf needs to have relays changed.
Jun 02, 2009 | 2007 Volkswagen Golf
Amp
Both power and ground connections must be used for proper operation. Connect 4AWG wire from both +12V connections to a fuse block with a 250A inline fuse, which will then connect to the battery. Ground both ground connections to a good, close point on the chassis.
Apr 07, 2008 | Orion HCCA-D5000 Car Audio Amplifier
Intallation of amp
Don't! The amp will draw many more amps than what the 12V outlet (like a cigarette lighter) can handle. Most amps are wired directly to the battery (for the +12V) with a 30A or higher fuse (reference the owner's manual)
Mar 18, 2008 | Visonik V2000T Car Audio Amplifier
No power turn on??
Does the voltage at the battery drop when you connect 12v to the remote terminal?
If not, there is too much resistance in the power/ground wiring.
If the voltage drops at the battery, either the battery is weak or the amp is drawing excessive current.
Dec 03, 2007 | Kenwood KAC-728S Car Audio Amplifier
Koolatron 12 Volt Battery Saver 70110 Logo
57 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
