Question about Sony KDL60EX700 60 in. TV
Hdmi input not working - Sony KDL60EX700 60 in. TV
  • 384 Answers
The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip".
Good Luck! I hope this helps.
Rich Lilja
Posted on Dec 28, 2013
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Hdmi output and inputs are no working. Only one works and I have to use it for everything just unplugging it and plugging hdmi cable running from bluray or game into cbl
I understand from your original message the main HDMI output works, and only one of the HDMI input is working. Which HDMI input is working? Bluray, Cabl/sat, or Game? Are you able to select the working HDMI input either from the remote, and front panel of the receiver, or just from input of the receiver?
Double check your settings for Audio output and HDMI controls (found on page 36 and 37) of the owner's manual.
Jan 06, 2014 | Onkyo HT-S3300 Theater System
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Nov 28, 2008 | Onkyo TX-SR606 Receiver
Hdmi input on pioneer pdp-r04u doesn't work. The component cables work, but not the HDMI. The digital audio works.
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
ENTER.
3 Press /  to select “HDMI Input”, and then press
ENTER.
4 Press /  to select “Setting”, and then press
ENTER.
5 Press /  to select “Enable”, and then press
ENTER.
there you go
Sep 04, 2008 | Televison & Video
Sony KDL60EX700 60 in. TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
