Question about Sony KDL60EX700 60 in. TV
Hdmi input not working composite
Hdmi doesnot work
  • 381 Answers
The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip".
Good Luck!
Rich Lilja
Posted on Dec 28, 2013
3 Suggested Answers
  • 49 Answers
SOURCE: Is there a super video to hdmi or composite video adaptor?
Hi cogitoneurop Yes is the simple answer, but depending on which way you need it to go, try this link http://cgi.ebay.co.uk/COMPOSITE-S-VIDEO-SVIDEO-AUDIO-TO-HDMI-CONVERTER_W0QQitemZ250487856744QQcmdZViewItemQQptZUK_ConsumerElectronics_VideoSwitches_SM?hash=item3a523d5e68#ht_3971wt_1054 hope it helps!
Posted on Dec 07, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: video inputs composite or rgb cause no picture but
> I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board
Posted on May 10, 2010
Only HDMI Video works. All other inputs/components have sound but no video
Some receivers have settings to switch the video circuits off when other parts are used. You will have to look around the manual to see if the video settings can be switched off.
Jan 24, 2016 | Audio Players & Recorders
No video or audio input through composite video or HDMI 1 on an Emerson 32 inch LCD HDTV
Check and replace its main power regulator board. It is not working. Might be faulty.
Jan 29, 2013 | Emerson LC320EMX 32 in. LCD HDTV
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
I have a Sharp LC-32D40U LCD TV. All the inputs for Composite (Y,R,W) are bad and only the S-video input on Input 2 functions. ( I have not tested the HDMI inputs as I ahve not HDMI source). I was told...
Unplug S-Video cable from tv then tyr Composite video input as if S-Video jack is hooked, related composite video input will not work.
Let me know if you need further help.
Aug 17, 2010 | Sharp Televison & Video
My hdmi does not work
What you need to do is connect it from both the red/white/yellow cable and your HDMI. Go to your video input on your TV to where you can see the display. Go to settings - Display settings, and switch your input display from composite to HDMI. Your screen will go blank. Once blank, turn your TV to your HDMI input and when you see the picture, save settings and completely unplug the composite cable. You should be good to go.
If this helps, please give me a 4thumbs up!
Respectfully,
Don
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
RCA HD52LP: Composite video inputs don't work
RCA Authorized service tech looked at it. He determined that the DM Module need to be replaced. The part alone costs $550 + labor. Since the HDMI and component video inputs seem to work, he suggested buying a VCR DVD combo with HDMI output which would be far less than repairing the tv itself. I'n researching the possibility of purchasing the part myself.
Jun 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Sep 09, 2008 | Onkyo TX-SR606 Receiver
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
No video on all input channels but input 3.....input 3 is perfect.
I believe on this unit input 3 in composit input directly to the av pwb. input 4 and 5 are hdmi and go thru main digital bd. If the composit inputs work and the hdmi's don't you most likely have a defective main digital pcb.
Nov 13, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sony KDL60EX700 60 in. TV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
