Question about Echo Garden
Long handle adjustment tool
How can I buy a carb.long handle adjustment tool with d shaped end?
    Top Expert:
  • 12,223 Answers
Go to www. repairclinic.com and get it.
God bless you
Posted on Nov 24, 2013
3 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: carb adjustment tool
It is probably a star or a square head. You should be able to pick up at any auto parts store.
Hope this helps
Kurt
Posted on Mar 18, 2009
  • 109 Answers
SOURCE: Getting the right tool to adjust carb on Homelite Blower.
Type in "AYP" on google...scroll down to "jackssmallengines.com, in the AYP part number box type number 530035560.
Posted on May 12, 2009
What kind of tools I u use on a poulan chain saw to adj the l and h screws
There make several different specialty tools for adjusting these...can you see what shape it is.....splined, double D, pac man,,etc..most poulan are splined that I have seen...????
you can order them online at several people laces just Google carb adjustment tools..
If you are in a pinch you can make a temporary one out of the end of a blue plastic box pen...just knock the top end of it out and tap it over the needle...I have used these many times on poulan..
Apr 12, 2017 | Poulan Garden
Craftsman schematic
Most are pretty simple the carb linkage should have a small moon shaped disc with three or four small adjustment holes for the bent tip of the throttle cable. After attaching the cable to the handle and snaking it to the carb. There is a small clamp that will hold the cable in the adjusted position .slide the end under the clamp and then connect to one of the holes on the linkage..slightly tighten the clamp and slowly move the handle unti the handle goes the full travel..then check to see it the carb linkage goes to full throttle and backs off to idle..if it does not..loosen the clamp and keep adjusting to get the desired full throttle and idle..May have to play with it a couple of times but it will adjust..good luck..
Jul 23, 2014 | Craftsman Garden
What is the proper tool part number for carb adjustment on316.791190
If the screws are star shaped then the tool to adjust them is 530035560, check out the web to find one.
Jul 24, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
Bought a brand new one. If I give it the gas it dies. It idles fine, but give it the accelarator and it dies?
It sounds like the carburetor needs a small adjustment. The higher end (more expensive) machines are prepped better by the dealers when they receive them for the area (climate) they are sold in. The Big Box Store machines or online sales outlets do not and they are sold as they were when they left the factory. A lot of the Poulan equipment uses Zama carburetors. They are set up and assembled in Mexico for the most part. So, that is that. You have an L (low) and an H (high) speed mixture setting screws on your carb. The L is the one that enables the carb to act as needed to allow the engine to acclerate. These are very difficult for the average user to access as the heads are shaped funny to preclude tampering (EPA rules). A tool to adjust the L and H screws (one tool) is for sale on Ebay. They do not have one at the big box stores or auto parts stores. A very simple home remedy I have found is to use the round end of a #22 wire terminal **** connector or ring terminal or what have you. They are made of plastic and can be lightly forced onto the head of these adjusting screws with a few small taps from a small hammer. Again, the L screw needs the adjustment. Here is a link to exactly how the carb should be adjusted and tuned.
http://www.zamacarb.com/tipspage.html
Nov 22, 2010 | Poulan Pro 25CC 2Cycle Gas Blower
Runs only when you toggle between choke and run
In this mode, you are keeping the fuel mixture richened. You may only need to adjust the carburetor (if you can) to get the machine to run right. Older Troys had splined carb adjusting screws (Zama carb) and some have D-shaped screws (Walbro). There are tools for sale on E-bay that fit these screws...or you can fashion a homemade device on them and adjust....aluminum tubing or the metal crimp end of an electrical connector (the plastic collar can be forced down over the head of the carb screw allowing you to turn it). Properly adjusting the carb on these requires a lengthy explanation. If you get to, and can turn the screws, don't turn them more than 1/4 turn either way. Do it while the engine is running to notice the resultsl
Oct 03, 2010 | Troy Garden
My Husqvarna 128ld trimmer will run but only at low rpm. I cant find a tool to adjust the carb. If I choke it 1/2 it will run at higher rpm, I suspect a fuel problem. It started in an instant.
If it is a newer trimmer it has a little plastic deal on the adjustment screws to prevent adjusttment.(epa). You have to break that off then a screw driver will work. Some are tough, turn hi speed screw counter clockwise it will rev
Sep 26, 2010 | Husqvarna 28cc Gas Line Trimmer
HOW DO YOU ADJUST THE CARBURATOR ON A POULAN P3500 STRING TRIMMER
Due to EPA regs, users are supposed to be restricted from adjusting carbs, but there are special tools provided by the manufacturers for this purpose. Only service techs are supposed to have them. Most carbs have an H and L adjusting needle on them. Some are Zama, some are Walbro and some are imitations of the 2. Some have "splined" heads, some have "Pac-Man" type heads (with small V-cut in them), and some are "D" shaped. With some ingenuity, one can fashion a tool to use to remove some of them. Small aluminum tubing can be forced over a splined head needle and turned. Small jewelers needle-nose pliars also may work.There are sellers that have tools for all these carbs. I would like to refer you to the Zama carburetor adjusting tech page.
Sep 22, 2010 | Poulan Garden
Gas adjusted wrong
Most chainsaws are built so all the adjustments are easy and basic. A standard flat blade screwdriver should be all you need to address most carb problems. Your problem is more likely the fuel mixture, the ratio between gas and oil. Check your owner's manual and replace your fuel with the proper mix..
May 26, 2010 | Poulan Pro Chain Saw 46cc 20"
My Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Apr 27, 2010 | Husqvarna 28cc Gas Line Trimmer
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
26 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
