Carrier 58ga pilot location - Heating & Cooling
Need to find pilot adjuster Carrier VR800A1020
it's under a cap that looks like a screw on the gas valve remove cap next to where the pilot tube connects, turn clockwise to increase pilot flame. probably time for a new thermocouple tho
Mar 12, 2014 | Heating & Cooling
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
My carrier furnace pilot will not light...what to do?
If this a 3 wire pilot replace it. If this is a standing pilot you need to replace thermocouple. Any other type ignition let me know and I will follow up with you. James
Jan 10, 2010 | Carrier 38CKC042 Air Conditioner
Where do i locate the pilot light/furnace
Are you sure that unit has a pilot light? It looks like a portable through the wall heat ****.
Nov 23, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Gas heater won't ignite
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Nov 16, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
The pilot does not light in the furnace
I assume that this is a rather old unit if it still has a pilot light. If the pilot will not stay lit, genrally the thermocouple is the culprit, however it could be the gas valve as well.
Jul 12, 2009 | Carrier Heating & Cooling
Carrier Forced air furnace will not ignit.
Skeeter is prob right your flame sensor is bad.. clean it or buy a new one, give your supplyer model number or bring it in... take a pic before disconnecting it.. If it fixes the problem, skeeter gets credit.. Thanks
Dec 04, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
