Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Random, intermittant blue lines
We are getting random horizontal blue lines in the picture, mostly in 1080i, and when the picture we are watching is dark, like a night scene. This has just started. We've had the TV since 2005. Any thoughts?
  • DBPlayer Jan 20, 2008
    We're not getting any red blinky lights. When we hold down the Device and Menu buttons, nothing happens as far as error code flashing.
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Jan 19, 2008
SOURCE:
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Have a 42" flat screen; the picture goes blank after two minutes each time after turning it on.
Hello
I have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.I don't have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.
And my problem is also resolved and its working fine.
Assistance by phone seven days a week.
1800 555 741
Thnaks & Regards
Apr 04, 2009 | Samsung SP42P2S Television
Insignia 42" black screen and line problem
Insignia and Geek squad has no other solution exvcept 1080i
Dec 26, 2008 | Insignia 42" LCD Flat-Panel HDTV
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
Sony triniton 28" crt tv i have got sound but no picture
Any set can be repaired it is the question of the cost and the availability of the parts.
The fuzzy lines with static noise is probably from an arcing in the high voltage multiplier or in the flyback windinngs. I am very sure that the flyback assembly with the high voltage multiplier, and most likely the horizontal output transistor will have to be changed just to start. It is also possible that there may be some failure in the power supply as well.
The set would have to be serviced by an experienced TV tech. As for the cost, it will be a bit expensive.
Jerry G.
Apr 20, 2008 | Sony FD Trinitron KV-28FQ75 28" TV
Mitsubishi vs-5041 picture intermittently goes off
my guess is convergance ic but to troubleshoot it the best soultion might be to get a can of freeze and spay it on the IC while the problem is happening and or tap the board/ic's to see if you have a loose connection,
Nov 29, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Picture noise blue/pink
do self test diagnosis here in threads or goto ctechnicians.com
Nov 03, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Blue lines
DB-IF IN FACT THE PIX IS GOOD ON OTHER INPUTS THEN YOU MAY HAVE A BAD FORMAT PCB.IF THE LINES ARE ALSO ON ALL OTHER INPUTS YOU PROBABLY HAVE A DETERIORATING POWER PC BD. PROBABLE COST OF REPAIR 350.00- 700.00.JOE TV
Oct 11, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
