Question about Sanyo EM-S8000 Microwave Oven
How to mount micro to wall - Sanyo EM-S8000 Microwave Oven
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Measurements to replace R 1460 over the range microwave
Almost all over the range micros are 30 inches wide. They did make a few 36 inch models but most are 30. Top to bottom back measurement can be between 16 to 18 inches. Most makes are similar in size. Back wall mounting plate will have to be exchanged since each company has a slightly different design but the wall plate comes with the new unit along with mounting hardware.
Apr 14, 2015 | Sharp Microwave Ovens
My Galaxy over-the-range micro #80009401 has a 4"
That sheet is called the Wave Guide Cover and must be replaced. It is made of Mica and protectes the magnetron and aerial.
Feb 03, 2011 | Kenmore Microwave Ovens
Need to install goldstar mv1515b otr microwave but do not have mounting kit. Where to buy? what does it look like? can i make a mount for it?
you can not get a plate . only plate that mounts it is the one that came with it . now I did this with my own sharp and this wil work with any . cut the wall benind same size of micro / this will let you slide it into the wall almost 3 in . giving you more room to cook and work on range top. she loved this . then attach the front by the bolts from the top or screw/s to the side of both .. makes a neet install ..****/ feed back pls .. dont forget the power goes in the top ,,
Dec 23, 2009 | Goldstar MV-1515 Microwave Oven
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
Oct 22, 2009 | Microwave Ovens
Who makes a microwave oven that mounts in an
Why can't you use the wall plate? Even if you had to use construction adhesive it would be better than nothing. If you are installing in an island setting then you will have to reinforce the cabinets as they would have to support the weight of the micro.
Eric
Oct 01, 2009 | Microwave Ovens
I need a wall mount bracket for a ge spacemaker micro, but I have no model #
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Sep 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
May 28, 2009 | Maytag MMV5100A Microwave Oven
Sounds easy...but
Installing one of these between two cabinets and supported by the one above it is a pain ..but even worse if you don't have the installation directions. If you are relatively handy and have some carpenntry experience, I'll walk you thru the way I install them. First off, I assume you are installing this above a stove and betwwen two wall cabinets.. You need to do a little preparation work first. locate the wall mount bracket and you should have a packet of hardware ( primarily two long screws that will be used to support the front of the micro from the cabinet above) If you have all this.. you'll need to determine if you are going to vent the micro back into the room or plan to vent it outside. The simplest is to vent it back into the rook thru a charcoal filter but if you are going tovent it outside, you have two choices.. one is to vent it up thru the cabinet and outside via ductwork that you buy..if the microwave oven is being attached to an outside wall then it is easiest to vent it straight out the back ( i say this because you have to orient the blower in teh configuration that you are planning to use) Let's assume you will be venting this back into the room ( that's the easiest ) and move on.. The wall mount bracket supports the back bottom of the microwave oven when you secure it and the two long screws will be used to bring the front of the micro up against the bottom of the cabinet above it... I normally locate the wall studs and then buy and fit a 1/2 inch piece of plywood onto the wall where the micro will be mounted. The microwave will project out 1/2 inch further as a result of this plywood panel but.. you can use lots of drwall screws to the secure the plywood to the wall studs and then you can mount the wall bracket onto this plywood without having to worry about where the studs are and if it will support the microwaves weight. Mount the bracket onto this plywood piece. I will use drwall screws and add flat washers to them to provide additional support. Once that bracket is installed, you will need to figure out how you are going to provide power to the microwave. If you are replacing an existing oven then you will probably have a power fees inside the cabinet =situated above the microwave oven. If not, then you will need to provide a power feed for this. In the old days, most of these appliances were hard wired into junction boxes but nowadays, most appliances are treated as removable and all you will need is an outlet box in the cabinet above. I suggest you bore a hole large enough for the power cord plug to fit thru the bottom of the cabinet so that you can plug it in. The next part is the hardest to accomplish.. If you look at the top of the microwave oven, you should see two holes near thhe front and on top. Those two holes have floating captive nuts inside them that the long screws ( included in your hardware kit) will be used to snug the front of the micro up against the bottom of the cabinet above it.. The trick is to measure from the back wall out to where these holes need to be drilled in the cabinet above so that they line up. You can drill bigger holes than you need and use oversize washers if necessary. If this sounds complicated ..it IS.. i have put many of these in and unless you are actually doing one, youhave no idea how involved this can be.. even worse with ducting to the outside.... I hope this gives you some tricks on how to install.. And um.. if you do get this all together, you will need some help actually putting it in place.. You'll need to catch the back of the microwave onto the tabs of the wall bracket and then feed the wire thru the cabinet while you lift the entire thing up to start the screws from the cabinet down onto the top of the microwave. I'm a big guy and have done these myself but it is not easy.. Hope this helps you.. Lastly, here is a link to the GE website where you can download the user manual and search their FAQ for install details ( in retrospect, I just should have given you that info).. http://www.geappliances.com/service_and_support/literature/
Hope this helps you...
Sep 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Sanyo EM-S8000 Microwave Oven Logo
24 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Oscar Netto
Oscar Netto
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
