Question about Dell (P513W) All-In-One InkJet Printer
Will not copy or scan
When i try to scan or copy i keep getting unrecoverable scan or copy error press cancel to contiune
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Unrecoverable scarn error X6650 series
The " unrecoverable scan error " indicates a scanner hardware problem. Please contact Lexmark Technical Support for assistance.
Feb 03, 2012 | Lexmark Office Equipment & Supplies
"unrecoverable scan error" .
The error indicates a scanner hardware problem. Your printer, probably, won't be able to perform its normal functions. I would highly recommend that you contact Lexmark Technical Support for assistance. Thanks.
Oct 27, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Try to scan and same error: unrecoverable scan error> But printing works perfect
"Unrecoverable Scan Error" message indicates a scanner hardware problem in your printer. Please contact Lexmark technical support for further assistance.
Jun 27, 2011 | Lexmark All-in-One Printer with PictBridge
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
My printer is Lexmark x5650. It prints well, but when i try to scan it starts making knocking noise after few seconds and continues 15 sec. then i get a message on printer's control panel display...
Unrecoverable scan error indicates a hardware problem. It's also evident with the "knocking noise" in the printer. I strongly suggest you contact Lexmark technical support for assistance.
Aug 27, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Mar 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
CANON PIXMA ERROR 5800
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
Dell (P513W) All-In-One InkJet Printer Logo
21 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
