Tc helicon voicelive
No power to unit
    Master:
  • 613 Answers
No power, then check the service disconnect and/or circuit breaker
Posted on Dec 08, 2013
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
The problem I have is the following: I have a powercore firewire and a powercore compact. They were sounding perfect until I bought three plug-ins: the TubeTech CL-1B, Tap Factory and Harmony 4. At...
Remove the offending plug ins and test. Then install one at a time and test. You may be running out of processing power to service all of them. Each effect requires a lot of computer resources. Look at your system idle time when you do a CTRL-ALT-DEL and click on the processes tab while running the plugins. The last item in the list is the system idle time. If this number is small, you are out of computer power and or resources.
Jun 05, 2011 | TC Electronic Helicon Harmony4 Harmony 4...
I have a shure sm58 Beta that worked fine at my last gig but when I went to reuse it at last nights gig did not work at all, luckily I carry a spare.I hadn't dropped it so can't understand what had...
The possibility to create a problem with the phantom power is out of te question. The phantom power power CAN NOT harm any dynamic mic. Check the connectors and try with another cable.Make all the tests at low volume settings.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Shure Beta 58A Professional Microphone
I want to buy a voicelive touch from the states,what do i need to do to make it work on australian 240 volt power
Check your pwer adapter as MANY of them will take 100 to 240 volts inout... if yours does, you are go to go... else here is one that will work as it is a worldwide type:
http://lcdpayless.com/productpage.php?productId=6679
Mar 12, 2011 | TC Electronic TC Helicon VoiceLive Touch...
I'm setting up a side rack of equipment i would like to incorporate into the tascam. I want to use an effects unit,bbe sonic maximizer a tc helicon harmonizer and possibly an parametric eq. I'm not sure in...
Get a dbx 400x Program Route Selector or something like it. (eBay). It will allow separate independent attachment and selection via front-panel switches of three processors and three tape decks to a single Tape Monitor loop; and the processors can be placed either before or after the processors or source, again via switches. If you have more processors you can always line some of them up in-line on a single processor loop. I do it on mine.
Feb 06, 2010 | Tascam 2488 Portastudio Multitrack...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
