Question about Dometic Heating & Cooling
The furnace runs but blows cold air - Dometic Heating & Cooling
  • 148 Answers
You meant blower running but no flame. check for opening at limit switch
Posted on Nov 24, 2013
SOURCE: furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
Posted on Dec 09, 2007
  • 108 Answers
SOURCE: amana furnace
This is no doubt due to failure of the "hot surface ignitor". This device lights the main burners for your furnace, and they fail a lot. I strongly recommend the replacement should be done by a technician.
Ray
Posted on Oct 25, 2008
Accurate Joe
  • 61 Answers
SOURCE: Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Posted on Nov 29, 2008
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
koolbreezes
  • 540 Answers
SOURCE: furnace not blowing hot air
Also did you check to see if you added a jumper wire to the thermostat rc--rh ! R-means power to C-(cool)_--- r-power-to rh is( heat)! TYVM!
Posted on Dec 08, 2009
Why is my furnace blowing cold air
Set your thermostat up to the highest temperature. If it comes on and blows hot air the stat could be bad, out of calibration, need new batteries, etc.
Feb 27, 2015 | Cars & Trucks
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
My heater blows cold air why? I have a REAB 1010s need manual
Check your thermostat to see what your fan switch is set on. There should be two settings - auto and on. If it is set on auto, the fan only comes on when furnace runs. If the switch is set on on, the fan on your furnace is running all the time. Which means when temperature in the house reach what you have set on your thermostat, the furnace kicks off, but the fan keeps running and blows cool air. Some people run their fan all the time, especially if they have allergies, because that's a good way to clean the air.
Jan 02, 2011 | Heating & Cooling
The floor vents in our house are blowing cold air instead of hot. What can we do to fix it? What would be causing this?
If the furnace is running and the registers are blowing cold air you have a problem with the furnace. Check to be sure the pilot lite is lite if this is a standing pilot, if not check to see if there is a flash code in the site hole in the bottom blower door of the furnace. Be sure the thermostat is set to heat and turned up.
Jan 02, 2010 | Heating & Cooling
Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
Nov 01, 2009 | Heating & Cooling
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Mar 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Open Questions:
Heating & Cooling Logo
76 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
