Question about LG Home Applaince LG DLG2102W 7.3 Cu. Ft. Gas Dryer - White
Dryer runs then stops panel flashes - LG Home Applaince LG DLG2102W 7.3 Cu. Ft. Gas Dryer - White
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Make sure it has good air flow
Posted on Nov 25, 2013
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
FEQ1442ES1 works but no heat
Instructions
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Jan 09, 2013 | Dryers
The dryer beeps when not running. It will start the cycle but then wii beep and stop. It seems to be running but every few seconds it flashes ERR. What can I do?
Open the front access panel or the lid and find the technician diagnostic sheet. Run ir through the diagnostic test and get an error code the sheet will tell you what to do. If you have anymore questions please comment me back.
Jul 30, 2011 | Dryers
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
Wont run
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs for about 3 min. then shuts off. Its not the reset. Let it sit for a few min. and the power comes back. Stop is flashing on panel.
have you cleaned the filter, so dryers stop if the dryer filter needs to be cleaned, also when you pull it out, clean underneath the filter, down in the dryer, lint gets down in there after a while......it may help.....good luck.....
Jan 05, 2010 | Dryers
Dryer stops and flashes E2 failure
Try unpluging your dry for about 5 minutes. Sometimes it just needs to reset itself.
Jan 31, 2009 | Kenmore Dryers
LG Home Applaince LG DLG2102W 7.3 Cu. Ft. Gas Dryer - White Logo
56 people viewed this question
Top LG Home Applaince Dryers Experts
Sal DeAngelo
Dan Webster
Dan Webster
Are you a LG Home Applaince Dryer Expert? Answer questions, earn points and help others
