Question about WeatherWorks Heating & Cooling
Paraglow heater how do i change the wick
Buffalo12980
  • 625 Answers
SOURCE: wickes
I went to a site that has questions and answers about a kerosun heater. from what I gathered, instructions on how to replace the wick are included with the replacement wick.
Posted on Dec 07, 2007
heavy389
SOURCE: I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Posted on Nov 30, 2008
  • 3 Answers
SOURCE: Directions for changing wick on Dyna Glow RMC95C7
You can find a free downloadable manual here.  There is a signup process, but it's free.
Hope this helps!
Les
Posted on Feb 04, 2009
anderza
  • 41 Answers
SOURCE: wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Posted on Dec 19, 2009
samanthaj08
  • 570 Answers
SOURCE: how do you change a wick in a dyna-glo rnc 95-c4?
Make sure to be very careful!
Posted on Jan 04, 2010
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
Paraglow heater radient 40 giving off stronger fumes than usual
Time to disconnect and have it looked at or replaced.
Dec 07, 2012 | Heating & Cooling
How to locate paraglow radiant 40 user manual on line
Toyo Stoves, Kero Stoves & Paraglow Radiant Stoves are almost identical. Actually, I think one manufacturer makes all three. The link below has about 70 Owners Manuals in pdf formats that you can download and print. Look for Radiant 40, there are 3 listings for that model number. Look at all three for the one that matches your model Paraglow.
http://www.toyotomiusa.com/ownersManuals_portableHeaters.php
Hope this helps you. Please let me know.
Mar 15, 2011 | Heating & Cooling
I need to change the wick on my dyna glo but do not have a manual can you help me?
When you buy the correct wick, the installation instructions will be with the wick. That's especially true, with the Kero World Wicks, brand.
Mar 11, 2011 | Heating & Cooling
When I light my Coleman Catalytic Heater, it burns
The wick isnt drawing up any fuel? Does this heater have a primer?
Could the wick be sitting above the fuel inside the tank?
You might just try changing wicks and restarting.
Dec 12, 2009 | Coleman Heating & Cooling
Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Oct 23, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
Nov 26, 2008 | Heating & Cooling
Heating & Cooling Logo
Top WeatherWorks Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a WeatherWorks Heating and Cooling Expert? Answer questions, earn points and help others
