Question about Panasonic Audio Players & Recorders
Panasonic dvd stereo system sa vk90d
Why surround creating noise while volume is full off
devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
  • 4234 Answers
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
Posted on May 15, 2008
SOURCE: my panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Posted on Jul 13, 2009
SOURCE: i have a panasonic sa-ht75 surround sound system,
You have probably solved this problem now, but incase you havnt, we had the same problem, the wrong lead came with ours, you need to plug the red and white into the audio out, and this should solve the problem, hope this helps
Posted on Jan 09, 2010
SOURCE: When I turn on the radio or insert a CD almost
That message means the audio amplifier IC´s are damaged
Posted on Jan 23, 2010
Cannot get the tv audio working. Radio iPod all work fine Panasonic surround sound sa-pt750
Hi. Make sure you get audio from tv from the right place. Ie audio out not audio in.
Nov 05, 2016 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Panasonic sa-vk90d error f61
This seems to stand for a power system failure. Possible faulty IC's in the power supply, or even a fan that doesn't work.
May 30, 2016 | Panasonic Audio Players & Recorders
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
My unlock not working
cant you repair my dvd stereo system sa,vk90d.have powe supply but no reading something.always all black
Jan 25, 2012 | Samsung Star GT-S5233 Cell Phone
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
May 09, 2011 | Panasonic SC-PT960 Theater System with...
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Jul 19, 2009 | Panasonic Televison & Video
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
