Question about Euro-Pro Faber Axia Isola Plus Kitchen Hood
Faber axia isola plus
In the winter, water drips out of it after I use it and it is getting insulation in attic wet.
How do I avoid ice dams on the roof of my house?
Better insulation in your attic is the first thing to do. Seal air leaks from home to attic and add attic insulation.
Oct 08, 2015 | Refrigerators
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
Parts -- # 133.0073.597
i need the same part. where did you order it from? thanks.
Jan 19, 2014 | Euro-Pro Faber Axia Isola Plus Kitchen...
Water condenses on outside bottom of freezer and drips on floor
I would not remove the bottom and replace the insulation. Where is the unit located in your home?
Nov 02, 2012 | Refrigerators
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Need attic insulation for ladder area
Buy some styrofoam panels at the hardware store. They're usually 2"x2'X4" and they only cost a few dollars. Also get a small tube of construction adhesive. Stick them to the top side. Styrofoam if one of the best insulators you can but. I have it on the inside, of my metal basement door. In the winter, when the temperature drops to 10 °, my cellarway maintains about 65°.
!/16" thick styrofoam protesct your hand from 170° coffee.
Aug 11, 2009 | Hand Tools
Malfunction halogen lamp
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 20, 2009 | Faber Axia Isola Stainless Steel Kitchen...
Euro-Pro Faber Axia Isola Plus Kitchen Hood Logo
62 people viewed this question
Top Euro-Pro Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Euro-Pro Kitchen Range Expert? Answer questions, earn points and help others
