Question about Coby Kyros Internet Touchscreen Tablet (MID7015-4G)
Ndroid charging port
I need a charger adaper please help
    New Friend:
    Problem Solver:
  • 5 Answers
I have the charger adapter.
Posted on Dec 17, 2013
My tablet won't charge
First try to charge it with a different charger, and test the factory charger on another device (you tablet may have the common micro USB connector). This will test if the charger or cable are bad. But if the tablet will not charge with a different charger and cable, and it is still covered under the factory warranty, return it for a refund or a replacement.
I have repaired many tablets with a bad charger port, and it seems to be either a poorly designed connector, or an open wire inside due to pushing in too ******* the cable into the port.
if you cannot replace the tablet, maybe you can find help from someone who can open the tablet and fix the charger port.
Nov 27, 2017 | Tablets & eReaders
How can I bypass the charging port on a textbook tablet
Peter, why would you want to by pass a charging port, if port is not working change it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Generic TAB Charger port Replacement
Samsung Tab 2 10 1 Charge Port Repair Fix Replacement TUTORIAL Win Samsung...
Jul 24, 2016 | Tablets & eReaders
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Tablet wont charge
you most likely need a new charging port,,,, they are available on amazon, just search for #### charging port , , #### being your model number,,,, or remove the back number and read the number on the harness for the charging port and amazon search that number,
you tube videos will show you how to replace that, if you watch the vid for replacing the screen, you will see the charging port being removed and you'll then know how to do it
Mar 31, 2015 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Nov 09, 2013 | Tablets & eReaders
My I-pad will not charge?
try computer usb port, to see if charger block is dead.
Oct 06, 2012 | Apple iPad 16 GB 3G Tablet PC
Galaxy tab p1010 not charging
Hi!Maybe this will work:1. Try a different charger.2. Connect it to a pc to see if that can charge your tablet (if this is working, it means that your charger is the problem)3. If none of the above works, then is the battery or the device itself that don't function properly and you should go to check it on a autorized service shop.
Hope this will help you!
Have a nice day!
Sep 28, 2011 | Samsung Galaxy Tab Tablet PC
Coby Kyros Internet Touchscreen Tablet (MID7015-4G) Logo
65 people viewed this question
Top Coby Tablets & eReaders Experts
Martin Murray
Hardware and...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
