Question about Pool & Spa
Wire a DFH-107-T - Pool & Spa
Quantum 610 error #107 Charger Inhibit
I just had same code. I took off rear cover and unplugged a rubber cap at the end of a long skinny group of a few wires. looks like a charging wire kinda. and unplugged the main plug. I did not unplug the two larger battery plugs. when I plugged them back in firmly everything was back to normal.
Mar 03, 2012 | Health & Beauty
The hard drive isnt spinning the disks. We can put in a cd or dvd or any disk and it does nothing.Do I have to just replace the hard drive?
You have a failed DISK drive not a hard drive. You can pickup a new one at Walmart, Best Buy or any other electronics store. Make sure to get a new DISK DRIVE that has a SATA connection and not the IDE connection. Your will take only the SATA type which is the faster of the two.
You can see more info and specs on your computer here at Dell. http://www.dell.com/us/en/dfh/desktops/dimen_c521/pd.aspx?refid=dimen_c521&cs=22&s=dfh
Good luck.
Feb 18, 2011 | Dell Dimension C521 PC Desktop
Dfh
> dfh
Replace your computer's keyboard, because it obviously is not working correctly.
Feb 01, 2011 | Promptoria WordsWorth Deluxe 2
I'm wanting to upgrade the RAM in my Dell Opti[plex GX620. The code on the motherboard is CN-0HH807-13740-632-030S. Any help would be greatly appreciated. Thanks
HI there Stephen,
Your Dell Optiplex GX620 has four memory slots which can accomodate a maximum of 4GB (DDR2). For the full information you can click the link below:
http://www.dell.com/us/en/dfh/desktops/optix_gx620/pd.aspx?refid=optix_gx620&cs=22&s=dfh
Please let me know if this answers your question. Thank you for using FixYa.
Dec 16, 2010 | Dell (J2628) Motherboard
Connect optilex gx520 with plasma tv http://www.dell.com/us/en/dfh/desktops/optix_gx520/pd.aspx?refid=optix_gx520&cs=22&s=dfh
What kind of plasma? If the plasma tv has a VGA input you can buy this:
http://www.amazon.com/feet-Coax-Resolution-Monitor-Cable/dp/B000067SMH
If it has DVI or S-Video, the GX520 will need a video card that supports those technologies.
Nov 26, 2010 | Dell OptiPlex GX520 PC Desktop
Error 107 (net::ERR_SSL_PROTOCOL_ERROR): Unknown error.
Error 107 is usually caused when your computers registry system contains errors or when certain system files are missing or broken; Error 107 problems are a sign of a very unhealthy computer registry...
However, most PC errors are caused by poor maintenance, but no-fear, repairing your Error 107 problem can be just as simple as following these 4 easy steps below:
1. Download the Error 107 Repair Tool :
http://errornerd.paretologic.revenuewire…
"You'll see a new pop-up window for confirmation."
2. "Save File" and follow the simple installation instructions.
3. Scan your computer with Regcure.
4. Click the "Fix Errors" button to repair Error 107.
Feb 05, 2010 | HP Pavilion DV5234US Notebook Laptop
I need the fuser reset code for the Ricoh Aficio 350
Try to reset with 5801 it means:
enter service mode with 107 and find 5801 and execute then switch on and off the copier.
Please try if it works.
Oct 15, 2009 | Ricoh Aficio 350e Printer
Pool & Spa Logo
29 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
