Frequency Listwhat is frequency of voa for midle east?
  • Office Equip... Master
  • 8,068 Answers
Here is the link to the frequency page. Do your digging.
http://www.insidevoa.com/info/radio-frequencies/2316.html
Posted on Nov 24, 2013
What is a relative frequency table
It is a frequency table where the entries are the relative frequencies
relative frequency= (frequency/sum of all frequencies). The frequency can be expressed as a decimal number or a percentage. In that last case, the total of all frequencies will be approximately 100% (due to rounding errors).
May 12, 2014 | Texas Instruments TI-83 Plus Calculator
What is the variable frequency drive?
VFD is a device used for speed control of 3ph induction motors & automation process control
Mar 18, 2013 | Hitachi Variable Frequency Drive Inverter
I have this mobile from saudi arabia, and when i came to usa the phone isn't working (no network)
hi there, i guess your phone has a different GSM frequency band, this is the frequency band of middle east: GSM-900, GSM-1800 and EGSM/EGSM-900
This is the frequency band of Unite states
GSM-850 and GSM-1900
This is why you don't have signals. thanks
Apr 30, 2011 | Cell Phones
I HAVE A CAR CD RADIO IN A JAPANESE IMPORT CAR THE RADIO IS SET TO JAPANESE FREQUENCIES IS THERE ANY WAY I COULD RESET TO BRITISH FREQUENCIES
Depending on the radio and the make of car , there is often a MENU setting that will allow country  change settings(which includes  the frequency changes ) for USA Europe and the Far East
If you have a MENU button (often labelled M ) , press it and scroll through the menu options(usually using the up (^ )or down( v ) buttons)
Unfortunately this facility is not available on many  car radios  so if yours does not have it  , then perhaps the cheapest option is a replacement radio (off Ebay)
Oct 15, 2009 | Car Audio & Video
Need radio frequency for West Lampeter Twp police department for police scanner.
East Lampeter Township Police (TAC)
155.595
155.595
71.9
West Lampeter Township Road
151.885
151.885
110.9
Aug 17, 2009 | Office Equipment & Supplies
I have problem with my car radio , its frequency standerd
Some radios have the option to adjust sensibility when scanning the frequency, check in your owners manual if your radio have that option. If you can't find that there or if you don't have it let me know about the brand and model.
May 06, 2009 | 2003 Ford Crown Victoria
Working principle of super heterodying receiver
you can find it easy with google, but here is how it works...the incomeing rf signal is mixed with a signal of another frequency from the local oscillator and then passes through a non linear device (semiconductor). after passing through the nonlinear device the output will contain the original frequency,the local oscillator frequency, and frequencies equal to those added together and subtracted from each other,these signals are then passed through filters to obtain only one which will be either the rf frequency plus the local oscillator frequency or the rf frequency minus the local oscillator frequency. This new frequency is then coupled to the intermediate frequency amplifier stages where most of the amplification takes place before the audio is removed and passed to the audio stages.
Jan 13, 2009 | Computers & Internet
Setanta channels
i need codes for starview box with ntl uk
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
Opel Astra G 2002 Radio Set from Japan to Middle east
simply your scanner range is from 77 to 90 mhz. you can not listen to any higher frequencies than that.
Nov 03, 2008 | Radio Communications
Fridge frequency
AC voltage (alternating current) rapidly changes from +ve to -ve and back again. The frequency with which it changes each second is measured in Hertz (Hz for short).
The speed of an AC motor (which is what you have in the fridge's compressor) is dictated by the AC frequency.
What this means is that if you connect a motor designed for a 60Hz supply to a 50Hz supply (which is what you'll be doing) it will only run at 80% of its intended speed.
Whereas running it faster than intended might cause damage to the motor, running it slower is highly unlikely to.
The only real effect that you will see is that the fridge will take longer to initially get cold and the compressor may run for longer periods to maintain the temperature. There is a slim chance that the fridge may also struggle to achieve the coldest setting.
Changing the compressor is not a simple job and needs to be done by an expert as it involves re-gassing the system.
Personally, I would just use it as it is and see how you get on.
Hope this helps,
Matt.
Mar 08, 2008 | Refrigerators
35 people viewed this question
k24674
jasbo
jasbo
