Question about HP Photosmart C8180 All-in-One InkJet Printer
Computer speakers put out static every 10 seconds with printer on.
Every 10 seconds speakers put out static. It stops when the printer is turned off. ?
  • rw41 Nov 24, 2013
    The Printer says it is a "Printer-Scanner-Copier" so I assume it is not a fax machine. The speakers are external and connected to the CPU tower. It is a wireless printer and I am wondering if it is emitting RMF every 10 seconds affecting the speakers. I believe the wireless feature is turned on. The printer is connected to the CPU via cable. Not sure how to turn off the wireless feature. Thanks.
  • 794 Answers
Would you be so kind to answer the following questions so that I may better help you. Is the printer an all-in-one with fax capability? Is it a Wireless printer? Is the wireless feature turned on? When you state "speakers" are you referring to the all-in-ones' fax speaker or the PC / laptops audio speakers? Are any of the speakers external and are theywireless too?
Posted on Nov 24, 2013
  •  John
    John Nov 24, 2013
    Do you still have the user's guide that came with your printer?
    If not, tell me the make & model of your all-in-one; I will try to locate a guide to walk you through how to turn off the wireless feature.
    That would be my first step in troubleshooting the propblem. Using the process of elimination approach.
  •  John
    John Nov 25, 2013
    Just a follow-up statement to see how you made out with your problem; were you able to resolve it- if so, please post how you did for others to know too, who may run into a similar problem. Thanks.
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
  When I plugged the speakers in today (Z-10)
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Jun 15, 2011 | Logitech Z-10 Computer Speakers
My left speaker stopped working. What should i do?
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 29, 2011 | Logitech Z-10 Computer Speakers
My dell inspiron mini 10 is making a random static noise
Muting does not mean turning off the speaker which means there can be occasionel static.
It occurs more if the is a magnet near!!
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Playback distortion
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 09, 2009 | Logitech QuickCam Communicate STX Personal...
Intermittent static in webcam recordings
Nov 02, 2008 | Labtec Webcam Pro
Speaker interference
Jun 23, 2008 | Microsoft LifeCam NX-6000 Webcam
2.0 CH USB POWERED SPEAKER SYSTEM
The static is probably coming from the computer sound card itself. Turn the volume down on the computer mixer it should limit the static you are hearing.
Jun 07, 2008 | Audio Players & Recorders
They Crashed
seem static electricty issue.
unplug computer from the wall socket and hold down the power botton for 10 sec. do the same with speakers. pluge back it should work.
hope it will help..
May 30, 2008 | Logitech X-240 Computer Speakers
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
HP Photosmart C8180 All-in-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
