Question about CDV Software Blitzkrieg Anthology for Windows
Blitzkrieg will not run on windows 8.1 - CDV Software Blitzkrieg Anthology for Windows
Please help
Change the compatibility settings of the .exe file that executes the game to an earlier o.s. That should work. If it is REALLY old, try DOSBOX
Apr 16, 2014 | CDV Software Blitzkrieg: Rolling Thunder...
Blitzkrieg will not work on windows 8.1
Blitzkrieg is a B***h of a game to get working on anything after XP
I own a copy myself and on windows 7 it runs really fast and the graphics are all over the place.
Unfortunately I dont think you can get it working unless you mess with the compatibility settings.
Nov 23, 2013 | CDV Software Blitzkrieg Anthology for...
I'm interested in buying Blitzkrieg 2 but seeing alot of issues with vista is it safe to buy this
you need to run them in compatability mode for xp
HOWEVER not to worry. Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select xp and click apply.Stat the game and hopefully it works.
Sep 30, 2012 | CDV Software Blitzkrieg 2 for Windows
My Blitzkrieg doesn't work on my Windows Vista Machines - is this a common problem and in that case - how do I solve it? Greetings Jonas
I think this is a common problem as Vista does'nt support many games and softwares...........Its better to use Win 7 friend.........
Jun 25, 2011 | CDV Software Blitzkrieg for Windows
I've uninstalled and re-installed Blitzkrieg Anthology with my CD-ROMs and I am not able to play the game, everything loads fine but when I try to play the game the screen map does not pop up, gives me...
Try updating your video card drivers. However, according to the specs, it's not supported for vista.
Vista site is equally unhelpful.
http://www.microsoft.com/Windows/compatibility/windows-vista/Details.aspx?type=Software&p=Blitzkrieg%20Anthology&v=CDV%20Software%20Entertainment&uid=&pf=36&pi=6&c=PC%20Gaming&sc=Strategy&vd=all&os=64-bit
Had a quick browser on the forums. Have you tried this vista dual-core patch?
http://bkpforums.com/phpBB2/viewtopic.php?f=58&t=3275&p=108961&hilit=screen+map+vista#p108961
Best of Luck
Jun 11, 2011 | CDV Software Blitzkrieg for Windows
Rolling Thunder will not run on Windows 7
Run it in compatibility mode by right clicking on the rolling thunder icon. And then click on Run it in compatibility. Let me know how it goes.
May 29, 2011 | CDV Software Blitzkrieg: Rolling Thunder...
I have tried everything, how can i run this program? I have windows 7 64-bit and i need help!! Any solutions?
This is an older game so it may not be possible, but there are a couple things I would try. I have linked to sites with a full description of what is needed for each suggestion.
Compatibility Mode and Set CPU Affinity:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
patch your game:
http://www.fileplanet.com/124619/120000/fileinfo/Blitzkrieg-v1.2-Patch
A quick search found other users who got Blitzkrieg to work, but I found none that were using Win 7 64 bit. 64 bit versions of windows seem to have more compatibility issues with older software than the 32 bit.
Assuming you have tried all of this, you might consider a dual-boot option for Win XP, or get an older PC for this and any other Win XP games (that don't like Win 7). I have found several of these.
Jan 29, 2011 | CDV Software Blitzkrieg for Windows
Blitzkrieg wont load on xp
If the game has been istalled successfully,on desktop right click on the game icon, select properties, switch to compatibility, then select run this program...... then select another OS.
Jan 06, 2010 | CDV Software Blitzkrieg for Windows
CDV Software Blitzkrieg Anthology for Windows Logo
91 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
Bill Boyd
EnergeeUK
Level 1 Expert
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
