Question about Sewing Machines
Bernina 630 Machine is buzzing when I turn it on.What does that indicate??
With regard to the question about the Bernina humming when it was turned on, mine was doing that today. I discovered that the lever on top where you place a bobbin to be wound was pushed over ever so slighty. When I pushed it back to the correct position the humming stopped! Hurray, no trip to the service place today.
Posted on Feb 17, 2015
3 Suggested Answers
chrismyers67
  • 53 Answers
SOURCE: Problem with Bernina 630
Sounds like one of your thread sensors is misaligned, covered in lint or broken, get a can of canned air and clean out your bobbin case area and you top tension area to ensure no lint/thread is blocking the sensors. If you still are having problems, find your local independent sewing store in your town that gives free estimates and see what they say.
-Hope that helps,
Chris
Posted on Jun 06, 2010
  • 166 Answers
SOURCE: I am considering buying a used Bernina 630 2006
These are lovely machines when properly looked-after and the usual advice applies - make sure you test the machine thoroughly before buying. I always test by threading different colours top and bottom to check the stitch formation - the top and bottom colours should remain top and bottom although a little bit of top underneath is not unacceptable. When you sew-off, make sure you check on a close full-width satin-stitch - the machine should be able to produce a good close zig-zag with 0.2mm stitch length and full 5.5mm width, without pulling th fabric through (you should never pull the fabric anyway, of course). Check thepattern balance by sewing-off a round buttonhole with a No1 foot - the circle should be perfect. You can also check balance using pattern number 437 (this is the pattern the factory uses) - the centre of the pattern should be exactly on the top of the triangular section. Make sure you check that the auto buttonhole functions properly with the 3A buttonhole foot. If the stitch formation is inconsistent or the machine is a bit noisy, check whether its been cleaned by looking under the stitch plate and take out the bobbin case and hook/shuttle - dont be afraid to give the hook race a drop of oil - this usually quietens a machine that's not been adequately cleaned/oiled, but if its still noisy, be a bit careful. Make sure sensors such as the upper thread sensor is working by just cutting the upper thread whilst sewing-off. If the machine fails to detect thread breakage and is a bit noisy, there might be a minor issue with the sensor and it may have been disabled. I've not generally found any major issues with this range of machines, but be aware that the main boards are extremely expensive to replace if there is a problem with any of the interfaces, so check, check, check as much as you can before buying. Lastly, I have seen a small number of these machines that appear to have a minor problem that they occasionally 're-boot' themselves - if this happens whilst you're testing - avoid - it can be an expensive repair on a machine that is no longer under warranty. Mechanics are rarely a problem with these machines, but ask to see evidence of routine maintenance service - a machine that's 5 years old should have had at least a couple of proper services and more if used very regularly.
Good Luck with your purchase and I hope it turns-out to be a 'good-un' !
Posted on Nov 14, 2011
My bernina sewing machine dealer has gone out of business. I need a source of oil for my Bernina 780 and clip for the stitch plate for my 630.
any sewing machine oil will do the job
parts can be obtained from the bernina spares on their web page , and from most sewing machine repair shops on order
Jul 01, 2017 | Bernina Sewing Machines
Can I fix a Bernina Artista 630 Y Axis sensor myself?
Have you consulted the owner's manual, SetUp - pg 92 re screen calibration? Try going through the SetUp function again.
BERNINA Support Machine and Accessories Finders and Software Support...
Feb 16, 2016 | Bernina Sewing Machines
The power switch is bad on my bernina sewing machine
I would suggest taking the machine to a sewing machine repair shop, since it's a Bernina.
Nov 10, 2014 | Bernina Artista 170
How can i get a manuel for Bernette 600 deco
Currently, I saw a Bernette 600 Deco manual for sale on eBay; also he Bernette 500 Deco manual is available for download on the Bernina site. Before I purchased one, I would call Bernina to see if they have one you can either download or purchase. Their number is 630-978-2500. I also found one for sale for about $14.00 here: Bernina Sewing Machine Manuals Instruction Manuals
Sep 12, 2014 | Sewing Machines
Why won't Bernina Artista 630 turn on?
If the machine won't power up its most likely a problem with the power board inside of the machine. I have replaced a bunch of bad power boards on the 600 and 400 series Berninas over the years. The 600 and 400 series machines use the same board. I service and sell lightly used Berninas on eBay under the user name bushvideo.
May 24, 2014 | Bernina Artista 180
Bernina Aurora 450 Sewing Machine
If the buzzing noise is coming from the motor it may be the suppressor on the way out and unfortunately for a Bernina it will be a shop job, if the buzzing is coming from the foot control then you can undo the foot control and take out the suppressor and discard it.
Mar 10, 2010 | Sewing Machines
Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Mar 26, 2009 | Bernina Artista 180
Bernina Artista 630 Turns Itself Off
My troubleshooting would involve taking it in to a Bernina certified technician as it would involve pulling off the covers of your machine for a look. Often this can be the cause of overheating due to high levels of lint build up from people using compressed air to blow out their machine (compressed air is notorius for blowing lint into other areas of the machine) I have also seen the odd plug end swell because customers use harsh cleaning products and it will then not seat properly.
Jan 03, 2009 | Bernina Artista 180
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
