Question about Whirlpool RBD305PDS Electric Double Oven
CAN NOT CONTROL BOTTOM OVEN
I just had my control panel fixed by Fix your board .com . Worked great until I just tried to use my lower oven. The controls for upper and lower oven do not work. Everything else does.
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Posted on Nov 28, 2013
fridgetech
  • 473 Answers
SOURCE: Had a power failure and now getting a PF E1 error on the control panel
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Posted on Nov 23, 2007
SOURCE: upper oven locked and control panel is not working
First off this oven sucks. Now to fix the problem replace the Fuse assembly with #4451042 an $11.00 part. SHUT OFF THE POWER AT THE BRAKER PANEL FIRST. Then open the lower oven door and remove the two small screws that hold the side trim pieces, slide them up a bit to remove. At the top of the track remove two more small screws that hold the display panel in-place and lift the cover up and away from the oven. The fuse is inside of a clear plastic tube with a female spade connector at each end of it. replace the failed part and put things back the way that they came off. Next time don't by a Whirlpool.
Posted on Jul 09, 2008
EllaWatson25
  • 725 Answers
SOURCE: i replaced the control board in a double wall oven
PF simply means a power failure and simply needs to have the breaker reset to accept the new board that you replaced. There are times when you may need to replace the breaker that controls you oven electricity.
Posted on Oct 21, 2009
apart4u
  • 213 Answers
SOURCE: Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
  • 417 Answers
SOURCE: I have a whirlpool rbd245pbd8
Hi
I'd guess you have a wrong wiring connection it sounds as if you may have crossed over the live input and output wires which would give you this condition.
Posted on Dec 18, 2010
I have a whirlpool accubake self cleaning oven.. when trying to use the self clean option it now states e1 f5 in the digital screen what do i do know?
Most commonly that is a runaway temperature error which usually means the temperature probe is bad and needs to be replaced. If you need more detailed instruction or help making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 26, 2017 | Whirlpool Ovens
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
I have a double electric Whirlpool oven and it quit working - the control panel is black - I can't get it to come on at all.
I think Whirlpool and Jen Air use the same display board, It's worth a check anyway.
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Nov 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Jenn-Air JJW8530 LCD panel does not light up
Good luck.
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Oct 08, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jjw9630aab panel is dim
See other posts regarding replacement of capaciter #C3 on control board, cost of capaciter approx 65 cents.
work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
Good luck.
Mar 25, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Whirlpool RBD305PDS Electric Double Oven Logo
77 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
