Question about Duplo CC-228 DocuCutter Card Cutter, Up to 130 business cards per minute, 6 pre-programmed jobs and 6 programmable jobs, Accepts a wide range of paper stocks up to 130 lb. cover/350 gsm, Ideal for full-bleed business card applications, Also great for postc
Machine total reset
Not cutting correct jobs
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
My vehicle stopped dead at set of lights and would not start, called RACQ he installed new battery $165 Stated that was problem, drove less than 1/2 kilometre down road, felt the vehicle ****. Continued...
Sounds like you have a fuel issue. It could be a fuel pump cutting in and out. It could be fuel pressure regulator, or an injector not spraying correct. I think it's time to find an honest educated repairman.
Mar 02, 2011 | 2001 Hyundai XG300
We have 2 IBM Wheelwriter 2000. Both experienced the same issue within 1 month. Upon printing a stored job, the carriage returns to a point mid line and all margins and tabs are then out of sync. The print...
Something in the software programing has gotten an error. Unplug the fax machine and wait over night. Plug the machine back in and reprogram it. This should solve your problem.
Sep 20, 2010 | Office Equipment & Supplies
Problem:the waste ink near full.what should i do?
That machine doesn't lie, anytime I've had that error on that machine it is really full. It means you need a new absorber installed and the counter reset by a shop.The absorbers are under the printer and cover the entire bottom of the machine. That means the print engine, scanner, all circuit boards and cables have to be removed just to gain access. I do that job in the shop for $90.75 total.
Jan 12, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Recently purchased a vista pivot shower door - there are no included instructions 1505D-36NG06
instructions for shower door installations are very important to have,..i have installed over 100 of them and i still wouldn't attempt one without instructions,.your totally best to do the research it takes to get the instructions needed for this job,...there are certain cuts and measurements that are very dependent on specifications given by manufacturer to be right,....one wrong cut domino effects the whole job,....good luck
Jun 11, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Need to reset an account in the job templates, and
When you browse in via the IP address, the Centreware Internet Service (CWIS) will ask for your username and pass word for certain operations. On the 7132, the username is 11111 and the password is x-admin (all lowercase). If that does not work, it may be that you exceeded the login attempt limit and will have to power off the machine, wait 1 minute and then restart it. This process usually takes less than 3 minutes total.
Apr 14, 2009 | Xerox Office Equipment & Supplies
Safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Nov 26, 2008 | Lincoln Pro Cut 55
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Dyson cut out
Hi
new motor required easy job to do go to this site for service manual.
http://dysonmanuals.llc.nu/index.htm
Mar 12, 2008 | Dyson DC08 Cylinder Bagless Canister...
Washing Machine Problem
It sounds like the control board has failed.  You will need a qualified LG technician to check this out.
Jan 20, 2008 | LG WM-1485FHD Front Load Washer
Duplo CC-228 DocuCutter Card Cutter, Up to 130 business cards per minute, 6 pre-programmed jobs and 6 programmable jobs, Accepts a wide range of paper stocks up to 130 lb. cover/350 gsm, Ideal for full-bleed business card applications, Also great for postc Logo
Top Duplo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
