Question about Nordic Track Exercise & Fitness
Nordic track t5z1 conveyer belt will not run and red light on control board flashes 5 times
Conveyer belt motor will not run,red light flashes 5 times on control board
4 Suggested Answers
  • 1212 Answers
SOURCE: apex 4100i nordic track treadmill.
Check the fuses on the motor control board, under the lower hood. There are usually 2 of them, and they are ceramic so you need to test them for continuity with a meter or test light/ buzzer. One is usually 10 amps the other is usually 15 amps.
These will blow when the treadmill is used on an electrical circuit that is inadequate for the mill. The way many houses are wired today leads to this issue. You can trip the reaker int he box so the affected branch is no longer energized and follow the wiring- at each outlet, remove the cover, and look to see if the wires are just stabbed into the back of the outlets. While this is acceptable for code, it is not acceptable for loads like a treadmill. Most of the time the wires cannot be extracted without damaging the outlet, so get enough outlets for the run, and with the new outlets, make sure to attach the wires under the screw heads. Black (sometimes red) to brass screws and white to silvery screws. and make sure the ground wire is attached to the green grounding screw. If you would rather an electrician do it- that is a good idea, and make sure they put the wire under the screw heads,. Form a loop in the wire clockwise as this is the direction the screw tightens, if the loop is clockwise it will stay under the screw head.
While this may not eliminate the problem of fuses blowing in all cases- in those remaining cases heavier wire must be run to the outlet the treadmill is plugged into.
Posted on Jan 25, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Posted on Jun 20, 2012
ercupa190
  • 12223 Answers
SOURCE: nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Posted on Oct 01, 2012
Nordic Track C2255 no power to the console and the fan is running unable to turn of the fan, checked all the wires on the control board and the LED is fixed red.
This is a situation the controller board motor is Faulty.
They controlled the console CPU BOARD. with 8-12VdC
For CMOS Circuit.,this board has 3 control power supply Some IGTB is faulty: 1) Main motor 2) Elevation motor 3) Console Control
HOwever tight the connector coming from controller board motor to the Console very well, and clean it.
Otherwise replace the Controller board motor.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
https://www.youtube.com/watch?v=p6PkBZrh4KM
Nov 17, 2017 | Nordic Track Exercise & Fitness
I have a Nordic Track C2255. When I turn it on the motor run, but the belt won't move. I'm thinking that replacing the MOTOR CONTROL BOARD would solve the issue, but need to know before I spend the $.
You must observe 3 things:
Open the cover from motor
1) See if the Drive belt or belt for motor is Loose?
if does, adjust the 2 bolts for tension belt motor the deflection will be 1/8"
2) or Too tight loose the 2 bolts , and loose little until you have deflection for 1/8" and tight the bolts again, keeping the deflection for 1/8"
3) See if the belt is Cut!! replace it, by new one.
Blessing
whatsapp:+50588611441
Nov 01, 2017 | Nordic Track Exercise & Fitness
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
My nordic track 2000 lights come on but will not respond when pushing the buttons
adjust the reed switch, clean it , test for open or faulty, tight the connector very well, see the diagram attached, Replace batteries too
Jan 09, 2013 | Nordic Track Nordictrack Exp 2000...
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
C2050 belt does not turn
LUBE THE deck belt inmediattely, maybe you have WORN deck belt
2) LUBE the rollers bearing too
3) test the drive belt motor for worn, replace or adjust it
4) test the input voltage motor, if there are the motor need repair, See my personal TIPS.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 24, 2012 | Nordic Track Nordictrack C2050 Treadmill...
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
Belt on nordic track exp 1000 not moving today but worked this week. machine turns on though
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Nov 12, 2009 | Nordic Track /proform Treadmill...
Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Apr 18, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
