Question about Denon DP-47F Turntable
Denon DP-7F subweights
I need to locate some subweights for my Denon DP-7F. The new stylus needs a little weight. Any ideas? :garberwwr@earthlink.net
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Denon Master
  • 924 Answers
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Posted on Dec 08, 2013
  • 6 more comments
  • lance
    lance Jun 08, 2014
    Apparently, you are not familiar with the Denon DP-7F turntable. It has an electronically controlled, fully automatic tonearm. The manual does advertize subweights (0.1,0.2 and 0.25g) to help balance the arm.
  • Audio Service Clinic Jun 09, 2014
    Hello Lance. While I didn't have a moment to download to owner's manual, here are the specs.
    Tracking force: 1.25g (fixed) Suitable cartridge: T4P plug-in connector type. This type of tonearm takes a P Mount cartridge. The balance and tracking force are specifically designed for the P mount. All P mount cartridges are the same weight, and use the same tracking force, as well as the anti-skating. I've never seen one that was adjustable. This cartidge was designed for easy set-up. Plug in the cartidge, and replace the set screw. You do have the set screw, correct? It has a knurled head and goes into the side of the tonearm, by the cartridge with the hole.You must use one because the weight will definitely will be off without it. If you have any further questions, please contact me through my website. Thank you.
    Lance, Trying to get my latest post to you. Technical support from Fixya, has been notified and you will hopefully have the complete answer to you shortly.
  • Audio Service Clinic Jun 11, 2014
    Hello Lance, My apologies. Apparently there is some conflicting information on your turntable. I pulled the manual. Yes, it is supplied with a P mount cartridge, however, Dennon does offer a headshell to allow you to use any cartridge. When using an aftermarket cartridge, simply dial the tracking force dial back to zero, and turn the balance counterweight at the back of the forearm to allow the forearm to float in the middle of it's vertical motion. Then go back to the Tracking Force/Antiskating knob, and dial in the tracking force suggested by the cartridge manufacture. The anti skating is automatically set. Sorry for the confusion.
4 Suggested Answers
ripleymojica
  • 643 Answers
SOURCE: i just received a denon
Yes you will need to purchase a stereo that has a phono input. If not you will have to buy an amplifier for the record player. Some newer Yamahas have a phono input. Hope this helps.
Posted on May 25, 2011
Grubhead
  • 5455 Answers
SOURCE: do I need an adapter for playing 45rpm records on
The only adapter you will need for 45's are for the ones with a large hole in often used in jukeboxes.
Posted on Jul 19, 2010
petraman7
  • 1175 Answers
SOURCE: turntable speed erratic
Hi...
It doesnt sound like it's related to an Auto function ( auto lift tonearm end of LP lift)
so...The motor is the only issue.
It could be the motor drive circuit or the motor.
It's fixable by a qualified tech.
I'm not sure what it's worth to you though.
Posted on Jan 19, 2009
Denon dp-26F when i tried to play a record the arm just skated all the way across the record. is there a way to adjust the arm so it plays correctly?
The short answer is that you need a new stylus as the one you have is either broken or worn away so that it won't stay in the groove. It could also be out of place. Rubbing your finger on the stylus you should be able to feel it digging in. If you can't it's gone!
Nov 16, 2014 | Denon DP-26F Turntable
Adjust pitch
Register (free) at Vinyl Engine and download the service manual. The adjustment you need to do seems fairly simple. You will need a turntable strobe disk to get the the speed right, unless you have perfect pitch.
http://www.vinylengine.com/library/denon/dp-29f.shtml
Jun 19, 2014 | Denon DP-29F Turntable
Change stylus
You can download the owner's manual from:
Free registration is required before you can download.
Jun 01, 2014 | Denon DP-29F Turntable
Denon dp-7f sounds fuzzy
This could be caused by a poor earth wire connection to the cartridge.
Jan 12, 2014 | Denon Audio Players & Recorders
Replace cartridge stylus
Hi, my advise to customers is to buy the best quality audio gear you can afford. If you tell me your budget I will suggest a couple of carts that match. Cheers John. Styluscity
May 27, 2013 | Denon DP-26F Turntable
What cartridge to use on Denon DP-DJ151?
Anything that will fit the headshell. You can spend a few pounds or few hundred on them. It depends what kind of quality you want.
Dec 04, 2012 | Denon DP-DJ151 Turntable
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
I have a denon DP-7F direct table (1989)ust wondering about the point of the arm the head of the cartridge housing is very close to the record any way to get that adjusted higher?
If the tonearm balance and tracking force for your cartridge are adjusted correctly, ignore it.
Register and download the manual for free at vinylengine.com
http://www.vinylengine.com/library/denon/dp-7f.shtml
Eeeww, page 8 says the counterweight snaps on and the tracking force is factory set. Any self-repecting turntable should have precise manual balance and tracking adjustments. Or your counterweight is not on? Either way, I'd look seriously at getting the stylus checked for excessive wear if it's tracking too heavily. The manual says 500 hours of normal use. You'll be carving up your recordings.
Maybe post the question to the guys at Vinylengine
Apr 30, 2011 | Audio Players & Recorders
Turntable speed erratic
It is likely that grease has hardened and as the gears rotate that grease is interfering with normal operation. Take the unit apart and have a look at the drive mechanism, if there is something in the gears you should be able to see it.
Jan 01, 2009 | Denon DP-47F Turntable
Denon DP-47F Turntable Logo
198 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
