Question about Lands Phones
Att el 52251 hand set 2 not registering - Lands Phones
Can a base for the AT&T EL 52300 be replaced and where would I find one?
Try Amazon or eBay, otherwise you will have to by a new one complete with the hand held.
Oct 30, 2015 | VTECH-ATT At&t El52300 Cordless Phone -...
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
the base cradle, etc.
The manual is available from: www.manualslib.com
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
PROBLEM WITH THE BASE GIGASET A120
Thank you for these instructions. I have Siemens geigaset A120 with three handsets and one of the handsets stopped working about a year ago and my previous tries att registering it at the base station had failed and I was about to give up and buy a new set for 80 Euro, but I decided to give i one more try at registering and it worked the third time around. So do not give up. When one your hand sets stops working (no dial tone and can not call from it) try re registering as described above.
Nov 23, 2012 | Siemens Gigaset A120 Single Dect Cordless...
Como conectar bluetooth madcatz playstion 3
Antes que nada asegurese de que el dispositivo bluetooth este encendido.
Para poder sincronizarlo:
1. Enciende el PS3
2. En el men? Settings (Ajustes), seleccione Accessory Settings (Ajustes de accesorios) y presione X.
3. Presione X en el icono Register Bluetooth® Device (Registrar dispositivo Bluetooth®).
4. Despl?cese hacia abajo y presione X en el icono Register Headset/Microphone/Headphones (Registrar auriculares/micr?fono/auriculares).
5. En la siguiente pantalla, prepare el auricular para sincronizarlo con la PlayStation 3. Para hacerlo, presione el bot?n K1 durante 8 segundos.
6. Una vez que el indicador luminoso LED del auricular titile en azul y en fecha de comprarojo (lo que indica que el auricular ya se puede sincronizar), presione X en Start Scanning (Iniciar escaneo).
7. Una vez que se haya efectuado el escaneo, la PlayStation 3 reconocera todos los dispositivos Bluetooth que se encuentren dentro del ?rea de alcance del sistema.
8. Busque 8860 en la lista de dispositivos, seleccione el icono correspondiente y presione X para que se le solicite una clave.
9.Escriba 0000 (cuatro ceros) como clave y presione X en OK.
10.A continuaci?n, aparecer? el mensaje: Register completed (Registro finalizado).
Dec 28, 2010 | Mad Catz Bluetooth Headset for PS3
Le insecto la tarjeta sim le meto el codigo pin y despue me dice inserta tarjeta sim correcta
La carte SIM no es parte de el systema cellular. El telephono pertenece a tmobile, att or sprint? Y el sim?
Nov 08, 2010 | Sony Ericsson w580i Cellular Phone
Desbloquear att.net de mi samsung sgh-a767
lo mejor es formatar el mobil e comprar un smart sim card busca en la net a si consigues configurar lo que quieras
May 13, 2010 | Samsung Propel SGH-a767 Cell Phone
APN settings not correct
You may be right...get Att APN they may have to give you to register to att network with the Sim you have..or you may have to activate sim card not sure..
Dec 15, 2017 | T-Mobile Sidekick II
No lo detecta mi p.c
hi amigo
1/check los ide cables in el interrior de tu ordinador
2/chek al alimentacion cables
3/chek if the bios enables that ide port that u use with cd-rw
4/rate me cuz u gonna solve ur problem for sure
Aug 15, 2008 | Acer CRW 2410A (99.B7712.002) CD-RW Burner
Noggin
Cual es el numero de chassis?
Me parece que la r414 esta conectada al yugo y su valor es de 0.18 ohmios y 2 watt y el dz402 es un zener de 5.6 voltios.
Si la resistencia se esta quemando es posible que hay un corto circuito en el yugo.
Jan 31, 2008 | Televison & Video
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
