Question about Oster Kitchen Food Express Cooking Microwave Oven
Turns on but wont heat up food
Model OGB81101
Wont heat food up
the magnatron is probably burnt up...
how old is the unit?
what brand and model is it?
Mar 24, 2013 | Microwave Ovens
I have a kenmore sensor microwave model 565.60582990 it turns on but wont heat. what can i do to fix it?
The most common cause is the magnetron that heats the food, there are two other parts that can be a factor, the high voltage capacitor and diode. The magnetron is the most expensive, and if fixed professionally probably cheaper to replace the microwave oven.
Feb 07, 2011 | Microwave Ovens
Have ge sensor microwave model Je1660w
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave works fine, but wont heat food....
I would say the high voltage rectifier diode has blown.
See http://www.gallawa.com/microtech/diode.html for help in diagnosis.
Okay, now that I see the model number, that's a US model:
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Sep 22, 2008 | Microwave Ovens
Microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Oster Kitchen Food Express Cooking Microwave Oven Logo
22 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
