Question about Frigidaire Washing Machines
HIGH PITCHED dryer SQUEAL but clothes are drying...
Frigidaire FER211as2 dryer making high pitched squeal though clothes are drying. Don't want to run it anymore and break it. Belt looks good, I've been told bearing? bearing housing?
    Problem Solver:
  • 10 Answers
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Posted on Jan 20, 2014
2 Suggested Answers
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
LG dle3777w emitting a high-pitched squeal
Hello there and thank you for choosing fixya
If your dryer is making a squealing sound or a high pitch noise please look at the following
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
May 17, 2011 | LG DLE3777 Electric Dryer
Dryer makes squealing noise when running. What's wrong?
the idler or tensioner wheel that your belt rides on has a bearing in the center of it. This bearing is going out causing the high pitched squeal your hearing
Jan 23, 2011 | Fisher and Paykel DGGX2 Dryer
The dryer is making a high pitched squeal.
Most likely the fan belt is about to fail.
Otherwise it could just be a poorly greased part from the factory, I would lean toward dried out belt about to bust.
Sep 12, 2010 | Bosch Nexxt WTMC8320US Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
There is a high pitched squeal when i use my dryer
Jockey wheels are worn you need to renew if not too old ...over 7 yrs
Apr 08, 2010 | Frigidaire GLEQ332A Electric Dryer
Washing Machines Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
