Question about HP LaserJet 1020 Printer
Black line down right side of 3050 laserjet
I tried to use the copier, and am getting a black line sometimes 2 down right side of copy. sometimes have one on left side also. have replaced the ink cartridge. what else can i do?
  • 794 Answers
I would try a few of the following; try a fresh (clean) install of the printer on your pc; or try a firmware upgrade on the printer; or clean the toner cartridge transfer roller (it may even be scratched.)
Posted on Nov 24, 2013
  • 3 Answers
SOURCE: HP LaserJet 2600n
Yes, u can just clean the drums , I means the rolls inside the printer, just open the printer door , then remove the cartridge , then u can use tissues with a little of alcohol to clean the rubber rolls inside .
Posted on Feb 04, 2009
SOURCE: hp laserjet 3050 - black line down the center of
If the lines only appear on copies from the auto feeder and printing is clean, then lift the auto feeder section and clean the scanner glass underneath.
If printing and copying have similar 'streaky' results you probably have a bad toner cartridge - try a replacement. If that doesn't work you have a fuser problem - which is quite a costly repair based on the replacement cost of your unit
Posted on Mar 04, 2009
venexcsd
  • 1185 Answers
SOURCE: my 5 in one laserjet 3050 prints black line on
You have dirt on the scan bar head so it produces an image on the paper.
When you print directly from the PC it does not use the scan bar
Take the glass off and clean the scan head
Posted on Feb 07, 2010
  • 76 Answers
SOURCE: I am getting two black
there is a problem in your toner cartridge replace it
Posted on Jan 27, 2011
SOURCE: HP Laserjet M2727 is printing
The easiest thing to do is put another cartridge into the machine and to see if the problem goes away. Even if you can get a empty cartridge that is still working. If the black line is still down the left side after changing the cartridge the fuserfilm in your fuserunit might have a tear in it in which case you'll have to send it to a repair centre.
Posted on May 16, 2011
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Black line is printed on the right side when copying or faxing
This could be caused by a faulty cartridge or a build up of toner on the drum or fuser. Toner can also be on the rollers causing line to show up on the prints. Try first replacing your cartridge to see if the line clears up if not have your printer cleaned by a certified technician.
May 28, 2010 | HP LaserJet 3050 All-In-One Printer
When we send fax or copy it comes out black , can recieve faxes and print off fine .? hplaser jet 3050
Scanner's lamp damage
Try to open the lid on where we copy sheets of this paper hold down the sensor and press the copy button, see if the scanner lamp light, lamp power can be interrupted
Oct 27, 2009 | HP LaserJet 3050 All-In-One Printer
Black line along the right side near the center when copying ONLY
first, the line are in all printing pages, or only when you make copies?,
if the line are in all printing pages, maybe your fuser has damage the fuser film sleeve,(aprox, 10-20 dlls), if only this line are when you make copies, maybe the glass in the scanner are dirty(clean and try).
i expect this solution your problem
Aug 05, 2009 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 - black line down the center of copies, everything elese works
Feb 26, 2009 | HP LaserJet 3050 All-In-One Printer
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
3050
when we copy or scan we get lines at both side throught
the paper
Apr 15, 2008 | HP LaserJet 3050 All-In-One Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 1020 Printer Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
