Question about GE PT970 Electric Double Oven
Oven light won't go on when door is opened - GE PT970 Electric Double Oven
  • Rett
    Rett Nov 25, 2013
    I appreciate your follow up. I have a GE Profile 30" Electric Double Wall Oven and Microwave PT970SRMISS. The oven light works when I push the "oven light" button, so I know the bulb doesn't need to be replaced, but the oven light doesn't work when I open the oven door. Hope this clarifies my problem. Rett....
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
AFTER SELF CLEANING DOOR WON T OPEN AND CONTROL NO POWER
Is this a whirlpool product wall oven or free standing if so you will need to get door open to provide a model number then I can tell you If it has a thermal cavity fuse most models you can slide a flexible piece of plastic between oven top and latch and push to left to get door open keep me posted
Feb 16, 2015 | Ovens
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
Oven door won't stay closed, light on
If the door opens past the 90 degree level position, it means you need new door hinges.
Mar 06, 2013 | Thermador SM272 Electric Double Oven
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Says oven door is locked...it is not. none of the buttons respond and oven won't work. stove top does work. what could be the problem?
I had the same problem with my oven.Mine is a different make and model but try by opening your ovenand move your locking lever for cleaning look at the actuall hook that locks it and find where on the oven itlocks into sometimes there is a safety switch in that hole that gets stuck.Try by messing with the safety switch with a screwdriver or something to see if the door off light goes off.Good Luck.
Jul 17, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
GE PT970 Electric Double Oven Logo
23 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
