Question about Reliance 1996-2001 Ford Taurus Mercury Sable 3.0l Dohc Aternator
How much refrigerant does a 1999 ford taurus hold
I can't get into your system to answer this question. The answer is 34oz if totally empty. This means that unless your using a drum & charging cylinder, you will need (3) 12oz cans as you will loose a bit in transferring them. I hope you find a way to get this info into your system. John McCranie P.S. My email is mrac5@yahoo.com but your system says I'm already there but won't allow my password. Can you fix that?
Power generators
Posted on Nov 24, 2013
Freon capacities
34oz of R134 refrigerant.
Jul 25, 2014 | 2001 Ford Taurus
How much R134 refrigerant do I add to an empty A/C system on a 1995 ford Taurus?
You can not add to an empty system, with just air inside it
The system must be checked for leaks & repaired first
If that was done, then you need to pull a vacuum on the system
& see if it holds,I assume you know that,if not, you need a repair
shop with the correct A/C Equipment
The amount of refrigerant is on a sticker under the hood,also in factory service manuals & repair shops have it in similar data base
info.
Your referring to a complete charge of the system,not adding to it
That has to be done under a vacuum & you need some knowledge of the laws of physics pertaining to refrigerant
Helps to have the factory charts also, to look at ambient temp at the
time of charging & system pressures
Have a shop work on it
Jul 14, 2014 | Cars & Trucks
I'm just wondering how much power steering fluid a
no need to buy it in a gallon. about 2 qts if totally empty
Aug 09, 2011 | 1999 Ford Taurus
How to remove the drivers seat from a 1999 Ford Taurus
Remove the nuts & bolts holding
it to the floor pan
Disconnect the battery first,
to discharge the air bag system
Jun 27, 2011 | 1999 Ford Taurus
I need a diagram of how the plug wires are put on 1999 ford taurus station wagon
1999 Ford Taurus 3.0 liter V-6 VIN "2"
1999 Ford Taurus 3.0 liter V-6 DOHC VIN "S"
and
1999 Ford Taurus 3.0 liter V-6 VIN "U"
Hope helps (remember to rate and comment this answer).
Mar 07, 2011 | Ford Taurus Cars & Trucks
WHAT SIZE BATTERY DOES A 1999 FORD TAURUS LX HAVE?
If we had a manual we would look on it but some of us don't, that's why we ask questions n look for answers here. If you don't have an answer don't post stupid stuff like "duh look in the manual".
Feb 19, 2011 | 1999 Ford Taurus
Where are the fuses located in a 99 ford taurus
Passenger compartment fuse panel: The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses.
Power distribution box: The power distribution box is located in the engine compartment. The power distribution box contains high-current fuses that protect your vehicle's main electrical systems from overloads.
Additional details could find in this link: 1999-Ford-Taurus Owners Manual
Hope helps (remember to rate this answer).
Nov 08, 2010 | 1999 Ford Taurus
Need to replace ac condensor on 1999 taurus how do you do it
If your AC system is empty...The condenser is in front of the radiator.
1. Use ramps or jacks or a lift to raise the car so you can work under it.
2. remove the splash guard under the radiator.
3. Remove the bolts holding the tranmission cooling lines. These also may also hold the bottom of the condenser on the AC line side. Move the cooling lines away from the AC lines.
4. Remove the nuts holding the AC lines to the condenser. You may have to hold the fittings with a vise wrench to prevent bending the pipes.
5. Remove the other lower condenser bolt and use the access holes to remove the top bolts holding the condenser.
6. Lower the condenser out.
Reverse procedure to install the new condenser.
If you have the correct tools, this is a fairly easy job.
May 28, 2010 | 1999 Ford Taurus
1999 Taurus. A/C issues
ok firstible who recharge the system? you or an autorepair? or are you a mechanic? if you say the pressures are ok, what are the pressures at? and sound to me like the system is overcharge, please answer my questions so we can comunicate better, are you just a car onwer, or are you a mechanic because i see on you ranking than you have it high, that way we will comunicate better,
Jun 12, 2008 | 1999 Ford Taurus
1999 Ford Taurus A/C Out
you have a oil problem
Jun 11, 2008 | 1999 Ford Taurus
Reliance 1996-2001 Ford Taurus Mercury Sable 3.0l Dohc Aternator Logo
52 people viewed this question
Top Reliance Electrical Supplies Experts
GFTALON
wadingriver
wadingriver
Are you a Reliance Electrical Supply Expert? Answer questions, earn points and help others
