Question about Toshiba 32DF46 32" TV
32" toshiba 36a60 plays DVDs but not cable TV
32" Toshiba model 36A60 will play DVDs but not cable TV through the Comcast Digital Converter box. Was working just fine for quite a long time after they switched it over then suddenly the TV would just go out (turn to 'snow'). We would need to turn it off for a couple of days and then turn it on and wait for sometimes up to an hour before it would come back on. It would run just fine for couple of days and then go out all over again. However, we've been able to play DVDs whenever with no trouble at all.
    Top Expert:
  • Toshiba Master
  • 77,932 Answers
Did you switch video inputs from the remote, each input has its own menu item.
Posted on May 19, 2017
  • 135 Answers
SOURCE: Toshiba 32A33 32" TV
Hook up a dvd player to the rca jack inputs, select "video" on tv.
Press "play" on DVD...
Posted on Oct 11, 2008
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
  • 240 Answers
SOURCE: snow on toshiba 32" tv probably 8 years old
replace sr83 demag relay on main pc board its a 12vdc relay is comon problem with this unit.
Posted on Jan 09, 2009
SOURCE: toshiba TV CF27F50 no audio
check the speaker
Posted on Jun 25, 2009
  • 416 Answers
SOURCE: Will the Toshiba Model 36A42 work without a converter box?
No, you need a converter box if you plan to use an antenna. I hope this was helpful, best wishes.
Posted on Mar 30, 2010
Program my Toshiba 36A60 36' TV to a universal remote
Programming procedure differ to different brand of remote controls; and it is no practical to type in all here by this window. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
0028,0021,0020,0025 are the common codes that sets with most of Toshiba TVs.
Dec 15, 2013 | Toshiba 36A60 36" TV
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
Toshiba 36A60 does not show signal on main antenna/signal source. Antenna 1 went out first. Video 1 and video 2 seem to be slowly losing picture. There is only snow and static instead of a picture on Ant...
The tuner module is bad and would have to be replaced, the other concern is video 1 and 2 are now becoming snowy, at this point I would suggest replacing the tv set because there are two separate issues and the cost to repair in my view would not be cost effective, cheaper in the long run to buy new tv.
Jan 25, 2011 | Toshiba 36A60 36" TV
Need values of discreet components "C801" and "D899" on toshiba power input board #PB9362
Hi. Did you fix the problem, im looking for this values too.... Please help me!
Oct 18, 2010 | Toshiba 36A60 36" TV
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Aug 27, 2008 | Toshiba 32A33 32" TV
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Toshiba 32DF46 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
